Head Replacment - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-13-2012, 07:29 PM   #1
jackyl16
Fan#: 68270
What I Drive: 2002 "White Lighting" White SE
FF Reputation: 1 jackyl16 Good Standing Member
Head Replacment
So, at 106,000 miles, I decided to proactively change my head before I experience any problems. So, I tore about the engine and once I got to the Valve cover off, I saw a huge amount of sludge in the valves. I mean, I have never seen so much. I change my oil at regular intervals, always use good oil. What do you think has caused this? Also, since I am installing a new head, should I start fresh with synthetic oil or stay with tradition oil? Any suggestions on what type of oil I should use? My car doesn't have any oil leaks either btw. Also, I am changing out everything since the engine is torn apart, water pump, timing belt, (I am even changing out the starter since I can get to it). Should I change out the oil pump or will the oil pump last another 100,000 miles?
jackyl16 is offline
Old 12-14-2012, 09:00 AM   #2
FordNLNR
Fan#: 96745
What I Drive: '03 Comp Orange SVT / '03 ZTW
Points 266, Level 5
Points: 266, Level: 5 Points: 266, Level: 5 Points: 266, Level: 5
Level Up 32% Completed
FF Reputation: 2 FordNLNR Good Standing Member
Yikes. You may change the oil regularly, but I'm guessing someone else didn't before you came along. You might try a product called AutoRX that's supposed to help gently clean up dirty engines, but that one may be beyond anything in a bottle will help. I say, if it is running fine and not burning oil, keep doing what your doing.
Either way, check that PCV system. Replace the valve and the breather filter in the air cleaner housing. Make sure all of the lines are free from obstruction.
FordNLNR is online now
Old 12-17-2012, 12:41 AM   #3
amc49
Fan#: 96610
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
I wouldn't be looking to loosen ANYTHING up in there, think destroyed bearings, if head coming off much of it can be got off anyway............
amc49 is offline
Old 12-17-2012, 03:10 PM   #4
jackyl16
Fan#: 68270
thanks guys...and should I switch to synthetic oil or stick with stander?
jackyl16 is offline
Old 12-18-2012, 01:05 PM   #5
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
I have used standard oil for the entire life of my focus (9 1/2 years and 114,xxx and counting) with no issues, but if synthetic helps you sleep better, do it.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
