Can someone help with rims? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-13-2012, 06:55 PM   #1
cheekedave
Fan#: 103448
What I Drive: 2012 Focus SEL Silver
FF Reputation: 1 cheekedave Good Standing Member
Hey guys! Quick question.. I have the 2012 SEL, and I found a set of rims for cheap. I have the optional 17's on right now (All season) and want to go down to 15's for Winter only. The rims I found have the right bolt pattern (5x108) but the rim width is 6.5". Will that work having that width? I am going to get a 195/65R15 as that is whats recommended. I dont know if there will be enough clearance.
If anyone could help I would appreciate it!
Thanks guys!
cheekedave is offline
Old 12-13-2012, 07:05 PM   #2
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,045, Level 50
Points: 6,045, Level: 50 Points: 6,045, Level: 50 Points: 6,045, Level: 50
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 4%
FF Reputation: 9 Deftmetal Good Standing Member
The s model came with 15 inch wheels and the front brakes are the same between the two. Someone on here said that the steering is limited with the bigger diameter wheels so going down size shouldn't be an issue. I went down to 16's and i haven't had a problem
Deftmetal is offline
Old 12-13-2012, 07:07 PM   #3
cheekedave
Fan#: 103448
I just want to make sure I get the right rim :) The ones on tire rack for 15" is only 6" wide I believe. I dont know what 6.5" will do.
Old 12-13-2012, 07:59 PM   #4
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
Forum Activity 4%
I had 195 65r15 on my last car and when i switched to 18s that were 7.5 inches wide and all i noticed was worse gas milage with the 18's.
Old 12-13-2012, 08:05 PM   #5
cheekedave
Fan#: 103448
I guess my only issue/concern is having enough clearance for the calipers. These rims im looking at are 6.5"... I assume/hope they will fit! Does our car make any mention of minimum rim widths?
Old 12-13-2012, 08:22 PM   #6
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 7,940, Level 59
Points: 7,940, Level: 59 Points: 7,940, Level: 59 Points: 7,940, Level: 59
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 8%
FF Reputation: 11 Joeywhat Great Standing Member
15x6.5 should fit. No guarantees until you actually try them, though. Or just post up the exact wheel. Also make sure the hub size is correct.
Hatch Nation #29
Joeywhat is offline
Old 12-13-2012, 08:24 PM   #7
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
Forum Activity 4%
I just checked, my16 inch rims are 6.5 inches wide
Old 12-13-2012, 08:29 PM   #8
cheekedave
Fan#: 103448
I am getting 4 rims for $80 cash. I guess im having to take a chance. The guy said it came from an older focus so I only have his word to go by.
Sweet. So this will fit im sure. Thanks for checking!
Old 12-13-2012, 08:33 PM   #9
Joeywhat
Joeywhat's Avatar
Fan#: 85247
Forum Activity 8%
Older focus will NOT fit. Bolt pattern is different. You want 5x108, so make sure that's what you get.
Hatch Nation #29
Joeywhat is offline
Old 12-13-2012, 08:35 PM   #10
cheekedave
Fan#: 103448
Yes it is 5x108. The link to it is here: http://toronto.kijiji.ca/c-cars-vehi...AdIdZ439835279
Will touch them up but they seem pretty good for $80. :)
