SVT leaking coolant - Focus Fanatics
Old 12-13-2012, 03:04 PM   #1
Krishilbun
Fan#: 95983
What I Drive: 2003 Focus SVT Black 3door
FF Reputation: 1 Krishilbun Good Standing Member
SVT leaking coolant
Recently been parking on pavement and noticed I'm leaking coolant (very tiny portion) I've located area of leak.
Guessing that's thermostat housing. Leaking near bottom white cap. Thanks for any input.
Kris
Krishilbun is offline
Old 12-13-2012, 03:13 PM   #2
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
Yup the t-stat housing. Common fault. Hit up Steve at Tousley Ford and he can hook you up with a replacement Contour housing pretty cheap.
04 ZX3 Mostly Stock [3/13 ROTM]["Best Non-SVT" FITF '12][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 12-13-2012, 03:14 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Feel the bottom of the hose close to the thurmostat housing to see if the coolent is coming from between the hose and housing , if it is that is common and just needs to be taken apart (remove hose) and give the hose and housing a good cleaning and replace with a worm style clamp
If it is coming from the housing to head which I doubt then change out the o-ring and go to worm clamps and you should be fine , some early housings were eaten out by electrolysis but its rare
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 12-13-2012, 03:17 PM   #4
Krishilbun
Fan#: 95983
Will deff look into that.
Thanks for fast reply / confirming :-)
Old 12-13-2012, 03:49 PM   #5
jwill2489
jwill2489's Avatar
Fan#: 78236
What I Drive: 2003 SVT JRSC w/BBK
FF Reputation: 4 jwill2489 Good Standing Member
contour svt housing from tousley . done
jwill2489 is online now
Old 12-13-2012, 10:10 PM   #6
1turbofocus
FF Affiliate
Fan#: 1123
Coolent doesnt run up hill , his leak isnt showing to be at the bottom or sides of the housing but at the front upper side like the hose is leaking and running down , lets check the problem before just throwing parts at it
If it is just the hose then it can be fixed with a .60 worm clamp and cleaning the hose and housing , if the housing has to be changed he didnt loose anything checking it first ,
90% of the housing I have seen changed didnt need to be and a $2.00 o-ring would of fixed it with cleaning the housing of the goop
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 12-14-2012, 10:01 AM   #7
jwill2489
jwill2489's Avatar
Fan#: 78236
Did you read his OP?
"Leaking near the bottom white cap"
He even stated it was the freeze plug
Old 12-14-2012, 10:29 AM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Did you see the picture where the anti is on the screw ABOVE the bottom plug and where it looks to be wet under the hose , its worth a look ...no?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 12-17-2012, 10:34 AM   #9
robs02
Fan#: 84572
What I Drive: 02 CD Silver SVT
FF Reputation: 1 robs02 Good Standing Member
It is a common problem. Check the orings at the sensor and the aluminum plug. Also you may only need the thermostat housing oring and not a new housing. Geez everone always says to get a new housing. You may need a new housing but take your housing off and check it first.
robs02 is offline
Old 12-17-2012, 09:51 PM   #10
Krishilbun
Fan#: 95983
Havent had a chance to take apart yet but i have some days off coming up. Will figure out whats going on then. Thermostat is working though
Originally Posted by jwill2489 View Post
Is that what the cap is called? freeze cap?
