Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 12-12-2012, 02:29 PM   #1
yanivdan98
Fan#: 107246
What I Drive: ford focus 2012 black
FF Reputation: 1 yanivdan98 Good Standing Member
turn off lights auto when turn off car
hi
i have ford focus 2012 model and when i turn off the car and the lights are in auto model the lights are not turn off and stay on..
how can i automatically turn off the lights after X seconds when i turn off the car and automatically turn on the lights when i turn on the car?
note that in my previous chevy cruze it was possible..
thanks alot
yanivdan98 is offline
Fan#: 1
Old 12-12-2012, 02:33 PM   #2
suss6052
Sonic MK3 Crew #06
suss6052's Avatar
Fan#: 95752
FF Reputation: 12 suss6052 Great Standing Member
Unless there is something wrong with your car it is supposed to turn the headlamps off as soon as you turn the car off when left in auto mode.
Mine has always shut off as soon as I turned the car off.
Moderator for: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, Great Lakes Fanatics
suss6052 is offline
Old 12-12-2012, 02:36 PM   #3
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Ford Focus 2012 SEL Hatchback
FF Reputation: 3 VOLDAR Good Standing Member
I am sure your lights go off after 20 seconds after you turn your car off. It is a setting in your Sync main screen you should check and change to 0 so that the lights turn off when the car is turned off.
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
VOLDAR is offline
Old 12-12-2012, 02:48 PM   #4
yanivdan98
Fan#: 107246
hi
my lights mode were on auto and when i turn off the car i wait about more than 60 seconds (about 100 seconds and the lights didnt turned off)
where can i change that the lights turend off after car turn off after 0 seconds? maybe it will solve my program...
by the way is there any chance to do that even if the lights are on "Always On mode" that if i turn off my car the lights will also turn off?
thanks alot
Old 12-12-2012, 02:49 PM   #5
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2013 Race Red ST
FF Reputation: 2 cbdallas Good Standing Member
Mine was set to "0" from the factory, and I changed it to have a delay.
As far as the lights turning on when you crank the car, they will only turn on if it's dark outside. If the light sensor detects that it's daylight, it'll keep the lights turned off.
cbdallas is offline
Old 12-12-2012, 02:54 PM   #6
yanivdan98
Fan#: 107246
hi ,
in my country we need to turn on the lights even in the day (its a law)
therefore i want that the lights will always turn on..
1. So is there any chance to do that even if the lights are on "Always On mode" that if i turn off my car the lights will also turn off?
2. also you said that there is a option to set the delay of the lights..how can i get to this option?
thanks alot
Old 12-12-2012, 02:56 PM   #7
suss6052
Sonic MK3 Crew #06
suss6052's Avatar
Fan#: 95752
Originally Posted by yanivdan98 View Post
hi
thanks alot
If you leave the lights on manual all the time it will stay on for the 15+ minute delay or whenever the accessories have their power removed in order to preserve battery power, therefore its not a good idea to use this.
suss6052 is offline
Old 12-12-2012, 03:12 PM   #8
flingwing1969
flingwing1969's Avatar
Fan#: 91700
What I Drive: 2012 white platinum Forcus SEL 303A
FF Reputation: 1 flingwing1969 Good Standing Member
hi ,
thanks alot
The U.S. Focus is not equipped with daylight running lights (DRL - lights that stay on during the day). There is considerable discussion here as to whether or not the BCM can be reset to turn on the DRL feature in our cars without modification to hardware. If you want DRLs there are several options out there, including modifying your fog lights to run of an ignition on power source so they will turn on/off with your ignition key. It is a minor wiring cut/reconnect but should be done carefully by someone who is knows how. You could get a Canadian Focus too - DRLs are required there.
2012 Focus SEL 303A, moon roof, etc
2006 Isusu I350 4x4 (my wife's truck)
2000 Honda Shadow VT600 (my summer ride)
1975 Jeep CJ built
1974 Dodge W300 Power Wagon dump truck & 2002 Kubota B-21 tractor-loader-backhoe
flingwing1969 is offline
Old 12-12-2012, 03:18 PM   #9
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
FF Reputation: 7 BetaDnB Good Standing Member
What trim level do you have? Do you even have Sync? I set mine by using the control on the left side of the steering wheel and going in to the settings on the screen between the gauges. Mine doesn't have a setting for 0 seconds. The lowest I can go is 20 seconds. If you have your owner's manual look in there.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete
www.soundcloud.com/betadnb
www.facebook.com/betadnb
BetaDnB is offline
Old 12-12-2012, 03:27 PM   #10
yanivdan98
Fan#: 107246
hi
first of all, i have the europe model of ford focus...
second, how can i get into the Sync opton menu and set the delay to 0?
do i need the specific Bus for ? or is there any option to do it from the radio menu?
thanks
