Inaccurate temp gauge - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-11-2012, 12:23 PM   #1
mrskippy
Fan#: 107201
What I Drive: 2000 Focus ZX3
FF Reputation: 1 mrskippy Good Standing Member
Greetings, I want to preface this by saying that I know only a moderate amount about cars / repair - and yes, have looked elsewhere on these forums before presenting this question.
My 2000 Focus ZX3 (only 83k miles on the engine) has an odd issue with the engine temp indicator. When I initially start the engine, the indicator sits at cold all the way to the left, and eventually creeps its way up as I start driving (to the middle of the gauge generally).
Every once in awhile - sometimes on highways sometimes on city streets - the temp gauge will drop / not go up - even though the engine is sufficiently warmed up.
From what I gather, this causes the RPM's to sit at about 2000-3000 and causes me to burn excessive amounts of fuel. When this happens it is immediately noticeable that something is "off" and doesn't feel right driving the car.
I have taken it to a few dealers and all they do is plug in the computer and say there's no error codes. I've had them offer to replace the whole gauge dash saying that will fix it; but I'm not certain that is the issue.
From other threads I've gleamed that maybe replacing the engine temp sensor which is fairly inexpensive may do the trick - does anyone have any other ideas on why this might be happening / what is causing it?
Thanks!
mrskippy is offline
Old 12-11-2012, 12:41 PM   #2
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
an easy place to start is to forget about the temp gauge and look directly at the temp sensor output. You can do this by putting your LCD odometer in test mode, which displays the actual engine temperature in Celsius. Then, you'll have better information to convey to your mechanic.
On this thread, scroll down to Whynotthinkwhynot's post and read paragraph #2:
http://www.focusfanatics.com/forum/showthread.php?t=290621
Play with that Celsius test mode for awhile so that you're comfortable enuf with it to use it properly the next time your intermittent problem pops up.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 12-11-2012, 12:41 PM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
Sounds like the computer is not getting accurate temperature information occasionally.
(or the temp is truly too low, and you have a stuck open thermostat)
Could be the sensor, the wiring to the sensor, or even just the connector between them.
If you want to verify actual coolant temperature, just turn the heater on.
If the coolant is hot, the heater will blow hot.
If the coolant is cool, the air will not get heated up much.
Nest time the gauge shows the motor is cold (when you think it is hot), try the heater to verify if the coolant is cold or if the gauge is misreporting data.
elsolo is offline
Old 12-11-2012, 04:08 PM   #4
mrskippy
Fan#: 107201
I have done this before - the heater blows, no issues there ever.
Buddy of mine has an OBD -> bluetooth/smartphone app that I'm going to try and get in there to see what the actual temp in celsius is reporting as.
How expensive / easy to do at home is replacing a sensor / wiring would you say?
mrskippy is offline
Old 12-11-2012, 10:11 PM   #5
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
If you've 'done this before' you'd know he's not asking you if the blower works, but how HOT it gets.
amc49 is online now
Old 12-11-2012, 11:03 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,790, Level 73
Points: 12,790, Level: 73 Points: 12,790, Level: 73 Points: 12,790, Level: 73
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 99%
And that "test mode" referenced earlier will tell you if it's a gauge issue, or an issue with the sensor/wiring.
If the readout is OK, when the gauge reads wrong it's the gauge.
if the readout & the gauge both drop, the sensor or wiring are likely at fault...
hope that helps describe the diagnostics better for you!
sailor is offline
Old 12-12-2012, 04:45 PM   #7
mrskippy
Fan#: 107201
Oh thanks - I've never heard passive agression on the internet before, you're so helpful.
Explaining how to get to the test mode was extremely helpful. I've determined that more than likely the CHT sensor is bad. The readout and gauge are in agreement with each other - but the temp will go from say, 40C after 15 minutes of driving to 70C when I pull over and restart the engine.
Do you by chance have a reliable / trustworthy website for parts that you use that I could purchase a CHT sensor from?
Thanks for the help!
mrskippy is offline
Old 12-12-2012, 05:10 PM   #8
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 8%
What makes you think the gauge and readout are not correct in their reading?
elsolo is offline
Old 12-12-2012, 05:20 PM   #9
mrskippy
Fan#: 107201
I drive ~15 miles one way to work a day through both rural streets and highway - roughly 20-30 minutes in traffic one way total.
If by the time I am getting to the end of one of these trips and the readout tells me my engine is at 39C as it did this morning - I think it'd be safe to assume it's incorrect - it wouldn't be that cold after a 15 mile drive (correct me if I'm wrong?).
Occasionally while I'm driving the needle and readout will drop suddenly by 20C, then go back up to where they previously were.
That and when it reads low and I restart the engine it reads normal temps (by normal I mean the range that was mentioned in the post my_beautious_ZX3 linked to).
Additionally when the temp is low - I get revs much higher than normal, which (again correct me if I'm wrong) would happen if the sensor is reporting incorrect temps to the computer, also causing excessive fuel consumption.
Lastly, what led me to this is the fact that my normal MPG calculations every time I fill up my tank was showing that I was getting a lower MPG than normal.
mrskippy is offline
Old 12-12-2012, 06:36 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Ah, the added info helps!
We often worry about quick diagnosis just being a guess when we don't have all the info. - I'm SURE that's why elsolo was concerned....
Luck!
P.S. - Tousley Ford in Minneapolis area is closest to you, and one of the two dealers we recommend for internet purchases. They have a good rep here, and I've used them myself a couple times - they'll even try to talk you out of buying from them if they think you can get it cheaper locally! (after shipping) just Google them, then you could call for instant service. Oh Shucks, got it here (800) 328-9552
sailor is offline
