Revs staying high before idling correctly. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-11-2012, 08:15 AM   #1
steveplatt28
Fan#: 107192
What I Drive: 2001 Dark Blue 1.6cl focus
FF Reputation: 1 steveplatt28 Good Standing Member
Question Revs staying high before idling correctly.
Hi, hope someone can help me out. car has been running fine up until this morning. went to restart the car having already travelled 3 miles then leaving it for 10mins or so. Straight away noticed the engine light was on and it was running what i would call juddery. managed to get home and check out the problem online and took a punt at the coil pack as my local auto supplies had one v cheap. Fitted part and started up, car runs perfect except for engine light still on and the revs stay at about 1100rpm for 5 secs before settling to normal.
thought it was strange that both problems occured at he same time and is it possible the coil pack going has knocked something else out?
Would also like to comment at how amazing all the members are at helping out by continuously posting new ideas.
Any help would be greatly appreciated
Cheers steve
steveplatt28 is offline
Old 12-11-2012, 08:53 AM   #2
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 57,502, Level 100
Points: 57,502, Level: 100 Points: 57,502, Level: 100 Points: 57,502, Level: 100
Level Up 0% Completed
Forum Activity 18%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
I can't help you much with your problem, but I will suggest you get your check engine light codes read so you have a better idea what's wrong. I don't know about in the UK, but some parts store chains in the US read the codes for you free so it may be something worth checking out before you start tearing things apart on your car.
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
Old 12-11-2012, 09:05 AM   #3
steveplatt28
Fan#: 107192
cheers
hi, not heard of free code reading over here but would be worth asking.
Thanks for reply
Old 12-11-2012, 01:17 PM   #4
ErikJames04SVT
Fan#: 104253
What I Drive: 04' Black/Red Focus SVT ZX5
FF Reputation: 1 ErikJames04SVT Good Standing Member
I am having a similar issue with my 04' SVTF. Sometimes the things acts like the cruise control is on. I start it and it jumps up to 2500 or 3k rpms. othertimes it just idles a little high 1500rpms but there is no check engine light and its not throwing any codes. Keep updating this thread with what you find and i'll do the same if i find something.
ErikJames04SVT is offline
Old 12-11-2012, 03:06 PM   #5
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
Steveplatt, if you hold in the odometer reset button while starting the car it will go into "test mode" and this will display current DTCs, among other things. That's the gist of it, but you can search for more info here, google, youtube. I think you should make sure your wires and plugs are up to snuff also, you could have high resistance in a wire that klled the previous coil, the new one might handle it for awhile but will kill the new one too if this is the case.
ErikJames, you should look around here for info on the Idle Air Control valve (or IAC), it's a solenoid responsible for maintaining off throttle engine idle, and they are known to stick and cause problems like you're describing. They can be cleaned or replaced, if you want to replace it I've used a Hitachi one in the past that was about $60 and works fine, much cheaper than OEM. Search for "IAC cleaning how to" or something to that effect, it's an informative thread.
6SPD_soul is offline
Old 12-12-2012, 08:48 AM   #6
steveplatt28
Fan#: 107192
Talking great!!!!
drove the car yesterday still with the warning light on and after leaving overnight and starting this morning it is running perfect and the warning light has gone out. not sure how this has come about but the car has been started and stopped quite a few times already today and so far so good. will keep fingers crossed.
was wondering weather the coil pack threw the ecu when it went and it maybe re adjusted when the new one fitted???
cheers for all the replies
Old 12-12-2012, 08:52 AM   #7
steveplatt28
Fan#: 107192
cheers 6SPD_soul, will try that even though it seems to be ok for now as the car is over 10 years old now so it must be a bit gunked up!
Old 12-13-2012, 12:19 AM   #8
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
Old IAC problems can come and go............
amc49 is offline
Old 12-13-2012, 02:19 AM   #9
postfranksa
Fan#: 107263
What I Drive: 2005 Pitch Black ZX3
FF Reputation: 1 postfranksa Good Standing Member
yeah, will try that even though it seems to be ok for now as the car is over 10 years old now so it must be a bit gunked up!
postfranksa is offline
Old 12-13-2012, 05:33 AM   #10
steveplatt28
Fan#: 107192
Thumbs down Not so great
started fine this morning but when stopped and restarted again same problem back again. have replaced ht leads to no avail. think gonna have to get it put on diagnostics reader. also took off idle control valve to clean but it looked quite clean anyway. does anybody think that is worth changing before i get diagnostics done?
Cheers Setve
