TPMS programming failure issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-10-2012, 10:49 PM   #1
C264
C264's Avatar
Fan#: 62875
What I Drive: 2013 Performance Blue Focus ST
FF Reputation: 1 C264 Good Standing Member
I have a 2013 ST and I purchased a set of 9L3T-1A180-A TPMS sensors to be mounted in my winter wheels. I also purchased the FORDTRIGGER 8C2Z-1A203-A to program them.
I was able to enter into the TPMS programming mode successfully with the method described on the TireRack .pdf (using the push-button start activation method). Each time I got the center display telling me I should go out and program my front left tire, I would put the transmitter on the sidewall adjacent to the valve stem, press the button on the transmitter, and the little LED goes on, off in 5 seconds, but no confirmation horn. I pressed it again and again and again until finally the vehicle goes out of programming mode (horn chirps twice) and tells me that the programming has failed and to restart the process. So, I restarted the process three times to no avail.
I then tried to program the TPMS by entering the programming mode using the hazard button method described on these boards. There I also successfully entered the mode, but when I deflated the tires, nothing happened (no horn chirp).
What could be wrong?
Do I have the right sensors and transmitter for a 2013 ST (9L3T-1A180-A TPMS12 & 8C2Z-1A203-A TPMS19, respectively)?
Please help. Thanks!
T. J.
2013 Focus ST
1976 Lancia Scorpion
C264 is offline
Old 12-11-2012, 12:04 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Is this of any help? http://www.focusfanatics.com/forum/showthread.php?t=301692
Geezer is offline
Old 12-11-2012, 09:26 PM   #3
C264
C264's Avatar
Fan#: 62875
Originally Posted by Geezer View Post
Thanks, but no. I've already tried that. While the method of pressing the hazard button six times did also get me into the TPMS programming mode, but releasing the air in the tire didn't program the sensor, it just left me with a flat.
Does anyone know if the sensor part numbers I purchased are indeed correct for my vehicle?
T. J.
2013 Focus ST
C264 is offline
Old 12-12-2012, 08:15 AM   #4
JayDeZ
Fan#: 97919
What I Drive: 2014 Honda Accord Sport 6-sp manual
Points 1,466, Level 21
Points: 1,466, Level: 21 Points: 1,466, Level: 21 Points: 1,466, Level: 21
Level Up 66% Completed
FF Reputation: 3 JayDeZ Good Standing Member
They are the right sensors. My guess is either you have a bad sensor or the person that mounted them broke the sensor, or simply forgot to screw it onto the valve stem and it's not actually there.
Jay
JayDeZ is offline
Old 12-12-2012, 11:52 AM   #5
C264
C264's Avatar
Fan#: 62875
Dang, that's what I was fearing. However, when I went to try the passenger front tire first, it also didn't work.
T. J.
2013 Focus ST
C264 is offline
Old 12-12-2012, 12:18 PM   #6
JayDeZ
Fan#: 97919
Chances of having 2 bad sensors like that, espcially new is very low. I'd take it to another shop and ask them to check to make sure the sensors are bolted to the bottom of the valve stem. If not, take it back to the first shop and raise all hell.
If these are new Ford sensors, there is only 1 part number for all vehicles that use that style sensor. Its not a part number mix up.
Jay
JayDeZ is offline
Old 12-12-2012, 02:06 PM   #7
C264
C264's Avatar
Fan#: 62875
Thanks for the info!
T. J.
2013 Focus ST
C264 is offline
Old 12-12-2012, 07:05 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,813, Level 73
Points: 12,813, Level: 73 Points: 12,813, Level: 73 Points: 12,813, Level: 73
Level Up 91% Completed
Forum Activity 99%
C264 - just noticed the "other Car" info.,
NICE!
sailor is online now
Old 12-13-2012, 08:45 AM   #9
C264
C264's Avatar
Fan#: 62875
Update
So, I went to Ford to have them program it and NO DICE. They couldn't get it to program the new sensors either!
This leads me to believe that they're actually not there at all. The sensors are probably still sitting in a bag on the desk of my tire guy. I'm bringing it back tomorrow for them to break a bead and see if they're really there. I'll give you an update to this update after tomorrow.
@ sailor: Thanks! I try to keep the "fleet" interesting.
T. J.
2013 Focus ST
C264 is offline
Old 12-13-2012, 10:01 AM   #10
JayDeZ
Fan#: 97919
Ask them if you can go in the shop after the break the bead and confirm that the sensor is actually there. You never know when they might try to pull a fast one on you.
Jay
JayDeZ is offline
