Old 12-10-2012, 05:26 PM   #1
propbreaker
Fan#: 107171
What I Drive: 2000 se wagon
FF Reputation: 1 propbreaker Good Standing Member
Need help have spi missfiring
My wife wagon is a 2000 se wagon with spi engine. it started sputtering and missing like water in the gas. I put dry gas in it cleared up and ran fine for 2 days. Then it started missing like bad coil so today I changed the coil plugs and wires. It then would not run that well. I read the codes and the only one is o2 sensor bank1 sensor 2. am I misssing something car is high mileage but it was mostly highway and the compression is still good. I did check it and for timing belt slop and no issue. I am confused I thought sensor 1 would cause missing not downstream sensor2. Anything I am missing????
Help she needs for work and to hual the kids around
propbreaker is offline
Fan#: 1
Old 12-10-2012, 11:20 PM   #2
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
FF Reputation: 4 calebstubstad Good Standing Member
well the spi does drop it's valve seat alot, but idk the signs of it. there's a ton of forums for it that'll tell you what to look and or listen for. I wouldn't be surprised as you used spi, high mileage, and engine problem in the same sentence
Rally Revolution #43
[HOONIGAN]
Originally Posted by CotyM View Post
Yep... thats a fail... calebstubstad wins
calebstubstad is offline
Old 12-10-2012, 11:26 PM   #3
sailor
"Elder"
sailor's Avatar
Fan#: 57268
What I Drive: 2004 Pitch Black ZTS
FF Reputation: 48 sailor Great Standing Member
Naw, he's GOT good compression, It's more like the Water in tank thread right below it...
if it ran better after the dry gas i'd try some more, and maybe change the filter?
sailor is offline
Old 12-10-2012, 11:28 PM   #4
calebstubstad
Chef Boyardee
Fan#: 103240
I'm not super great with engine problems, but the SPI usually leads to dropped valve seat in my book haha. listen to sailor though, he knows more than me
[HOONIGAN]
Old 12-10-2012, 11:31 PM   #5
mikebontoft
Gets more V8
mikebontoft's Avatar
Fan#: 58647
What I Drive: 1994 Toyota 4Runner
FF Reputation: 74 mikebontoft Excellent Standing Member
symptoms before the dropped seat can be an intermittent loss of compression in one cylinder. It will misfire once in awhile. You can do a compression test on it with no trouble.
Not convinced it's the problem though.
SR #127 | '02 Focus SE "Foci" (5.0 in progress) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-selling) | '94 Toyota 4Runner SR5 "Roach" (daily-stockish)
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
Originally Posted by GonOvr View Post
I had a spare tire go up in flames once, my truck was hit with an rpg though.
mikebontoft is offline
Old 12-11-2012, 07:43 AM   #6
propbreaker
Fan#: 107171
I read thru the valve seat issue. I bore scoped the cylinders no valve seat issue. I think this is electrical or bad gas. There plugs were pitch black and smelled like bad fuel. The wife just filled it up and drove over 20 miles before it started missing. The only code was for downstream O2 no heated circuit. The car has over 260k not sure if the engine has that on it. Anyone have mass airflow go bad without a code?
Old 12-11-2012, 01:28 PM   #7
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: Molly teh SPI - 03 LX
FF Reputation: 3 crazy_urn Good Standing Member
I had a similar intermittent misfire issue with my SPI. Sometimes it would pop a code, sometimes it would not. I cleaned the MAF and cleared up the problem.
It is definitely not the valve seat prob. but thanks for the uneducated insults caleb.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 12-11-2012, 11:00 PM   #8
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Missed the "insult", thought the "high mileage, SPI,and Engine Problem in one sentence" was a chuckle....
Dirty MAF wouldn't necessarily "code" (in fact it probably wouldn't) so it's good to see a comment that THAT was the issue in a similar circumstance....
"Like" ing fuel as the issue, but with all the coil pigtail issues we hear about a look there wouldn't be out of place....
sailor is offline
Old 12-12-2012, 10:05 AM   #9
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
The insult comment was not directed at you. (hence why I said 'caleb', though I guess I could have been more clear.) I just don't appreciate cheap shots by uneducated noobs.
good call on the coil pack. that could also be the problem.
Old 12-12-2012, 10:08 AM   #10
mikebontoft
Gets more V8
Fan#: 58647
I don't see any insult there... it is what it is. mine did it. But it doesn't appear to be the problem.
