Dome Light Trouble - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-10-2012, 01:45 PM   #1
shagginwagon88
Fan#: 104475
What I Drive: 2003 twilight blue focus se
FF Reputation: 1 shagginwagon88 Good Standing Member
Dome Light Trouble
ok so my dome light gave out on me the other day and i have tried everything fuses new bulbs new dome light but when i turn on my reading lamps on sides and center it come on very dim anyone else have this problem before?
2003 ford focus se wagon
shagginwagon88 is offline
Old 12-10-2012, 09:01 PM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Check your connections to the light. If you have a VOM Meter;
1) Place it on the "volts" setting and read the voltage between the two posts that the lamp hooks up to, record voltage.
2) Then go between one post and a known good ground point and then the other post, recording voltage as you go. One should read zero volts, as the other should read higher or close to the voltage from step 1.
3) If voltage is the higher, you have a high ground resistance; if the voltage is close to being the same you have a high resistance in the positive line. You can try this with and without the lamps "burning".
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 12-12-2012, 10:38 AM   #3
shagginwagon88
Fan#: 104475
what do i do after that?
Old 12-12-2012, 08:58 PM   #4
MEJY1988
Fan#: 101883
Points 160, Level 3
From the info collected from above, you should be able to tell if the problem is with the ground wire or the positive wire. Trace down where the problem is and try cleaning the connections.
MEJY1988 is offline
