US to UK light conversions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-09-2012, 11:06 PM   #1
USAFGuerin
USAFGuerin's Avatar
Fan#: 107145
What I Drive: 2013 Silver Ingot FF Titainum
FF Reputation: 1 USAFGuerin Good Standing Member
SO... I just bought a new Titanium 4Dr and i need to figure out a way to get a fog light to work in the REAR. i don't want to install an exterior, and i would like to just convert one of the 3 brake lights (preferrably to boot-top) so that it would turn on and stay on with the front fogs. i've run into a few problems...
1) cut the wire to the brakelight and ran a wire all the way to the fuze relay in the passanger pannel. Problem was... the ground and the hotwire were both hot...
2) attempted to access the wires set behind the light control toggle in the driver side. Problem was... didn't light the rear.
my next option is to completely remove the front fogs and splice the wire from there to the back, but that is a LOT of work for a brand new car.
also, i could just run a toggle switch, but i kind of want to avoid that...
if there are any suggestions or alternatives, feel free to let me know!
USAFGuerin is offline
Old 12-09-2012, 11:50 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,933, Level 87
Points: 18,933, Level: 87 Points: 18,933, Level: 87 Points: 18,933, Level: 87
Level Up 17% Completed
Forum Activity 11%
Buy-Sell-Trade Rating: (4)
Doesn't that defeat the purpose of a 'fog light' (mounting it too high)?
Look into how the front fogs are switched by the light switch ...
121,000 members and still no sponsored racing.
iminhell is online now
Old 12-10-2012, 12:07 AM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,457, Level 75
Points: 13,457, Level: 75 Points: 13,457, Level: 75 Points: 13,457, Level: 75
Level Up 52% Completed
Forum Activity 99%
Not quite understanding #1, since "ground" can't be "hot"....
You're in the UK and they sold you a US car?
sailor is online now
Old 12-10-2012, 12:09 AM   #4
goingFocus
Fan#: 75386
What I Drive: 2005 CD silver ZX3 SES
Points 146, Level 2
Points: 146, Level: 2 Points: 146, Level: 2 Points: 146, Level: 2
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 goingFocus Good Standing Member
There is supposed to be an additional position on the headlight switch for the rear fog, click one and front, second click for the rear for as well as front fogs. Also, there is a pin on the back of the switch, I believe 83a, or 83b for the rear fog. Don't remember which, but if you consult your local Ford dealer service dept, I sure a tech will be able to pinpoint which one. It's a built in the EU lighting code. GL
goingFocus is offline
Old 12-10-2012, 01:03 AM   #5
USAFGuerin
USAFGuerin's Avatar
Fan#: 107145
Just a UK requirement. Doesn't really help, but one of those silly things they need for MOT/SVA
Old 12-10-2012, 01:05 AM   #6
USAFGuerin
USAFGuerin's Avatar
Fan#: 107145
Tried to wire it to the fuze relay... bad idea... but yes i'm military, so i bought my car from the states because i plan on eventually heading back :)
Old 12-10-2012, 01:07 AM   #7
USAFGuerin
USAFGuerin's Avatar
Fan#: 107145
I forgot to mention this is a US spec. there is no button for the rear fog, because there is no rear fog. i just need to wire a brakelight to make it turn on with the foglight so that i can pass the inspection for the UK req's. i'll look into that switchbox again. thanks!
Old 12-10-2012, 01:18 AM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Well, for "quick" wiring since you have a wire run already - if you probe around that relay box 'til you find what wire goes "hot" when the fogs turn on, just tap into that & you're done!
The rear light isn't high power draw, so this should be adequate. It's not like adding high power fogs in the front, when you'd use that feed to run a relay & direct power from the battery to power them....
More like when you're installing a stereo & you just need to find a switched power source & an unswitched one - any wire that supplies what you need is adequate 'cause the extra draw is low.....
luck!
