Old 12-09-2012, 07:30 PM   #1
jra4e
Fan#: 22006
What I Drive: 2001 Infra-red Focus ZX3
FF Reputation: 1 jra4e Good Standing Member
Odd headlight problem
I have an 01 ZX3. Two days ago my driver side low beam stopped working. Thinking nothing of it I replaced it with a new bulb. But after I installed it, the driver low beam still didn't work. So I started googling possible symptoms. Tonight the driver side low beam now works and the passenger side low and high beams do not. Could the problem be the relays are going out?
Thanks,
Joseph
jra4e is offline
Fan#: 1
Old 12-09-2012, 07:55 PM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
FF Reputation: 43 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (16)
the relays would be a good place to start.
Advocare 24 Day Challenge!
SkyPilot is offline
Old 12-09-2012, 11:41 PM   #3
sailor
"Elder"
sailor's Avatar
Fan#: 57268
What I Drive: 2004 Pitch Black ZTS
FF Reputation: 48 sailor Great Standing Member
I'd take a look for wiring harness grounds in the headlight area, it sounds like you are loosing ground intermittently.
Meter could help, but it might show ground even when it's inadequate to carry the load.
being an '01, even in NC it could be rusty where they connect to the chassis.
sailor is online now
Old 12-10-2012, 07:07 AM   #4
jra4e
Fan#: 22006
Update: this morning none of my low beams work and the passenger side high beam doesn't work. Only the driver side high beam works.
jra4e is offline
Old 12-12-2012, 04:37 PM   #5
jra4e
Fan#: 22006
Update 2. On my right side the plug on the right side headlight house came out and I put that back in snug and also my left side lights work now high and low. I will buy a new relay Friday and see if the problem still persists.
jra4e is offline
