Shaking around 50 mph. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-09-2012, 02:45 PM   #1
tnealley
tnealley's Avatar
Fan#: 10638
What I Drive: 2004 Black zx5 svt
FF Reputation: 1 tnealley Good Standing Member
For some reason my 04 SVTF shakes bad around 55 and up when im accelerating.. Just had new tires and balance and alignment.. What im reading is it could be a motor mount. So im wondering how you can tell what mount is bad or which one might it be.. The car just turned 90k so i know im going to be replacing stuff ...
tnealley is offline
Old 12-09-2012, 03:11 PM   #2
02ztsian
02ztsian's Avatar
Fan#: 14466
What I Drive: V6Mistake, 03 ZX3
Points 3,019, Level 33
Points: 3,019, Level: 33 Points: 3,019, Level: 33 Points: 3,019, Level: 33
Level Up 80% Completed
Forum Activity 3%
FF Reputation: 9 02ztsian Good Standing Member
Buy-Sell-Trade Rating: (14)
Did it shake before the new tires/balance/alignment?
02ztsian is online now
Old 12-09-2012, 03:44 PM   #3
tnealley
tnealley's Avatar
Fan#: 10638
no it started about 3 months after.. I took the car to Ga on a trip and it started about half why through the trip.
tnealley is offline
Old 12-09-2012, 04:20 PM   #4
Joni4TA
Joni4TA's Avatar
Fan#: 103196
What I Drive: 2003 Black SVT
FF Reputation: 2 Joni4TA Good Standing Member
I had both issues. I replaced my tires first cuz I could visibly see they needed it, and the problem went away. Then it sort of started up again... while repairing an exhaust weld I noticed I also have a broken motor mount. Hopefully that'll fix me up. I ordered a new (better than stock) one from newedgeperformance.com
Joni4TA is offline
Old 12-09-2012, 05:14 PM   #5
tnealley
tnealley's Avatar
Fan#: 10638
Thats what im thinking i have also.. guess its time to jack her up...
tnealley is offline
Old 12-11-2012, 08:17 AM   #6
bluedevil03
bluedevil03's Avatar
Fan#: 106558
What I Drive: 2003 blue focus se
FF Reputation: 1 bluedevil03 Good Standing Member
Sounds like you threw a wheel weight to me. Have them rebalanced using a roadforce tire balancer if it still does at higher speeds like then then maybe a motor mount.
bluedevil03 is offline
Old 12-11-2012, 09:06 AM   #7
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
Level Up 0% Completed
FF Reputation: 34 tukaniSVT Great Standing Member
^^ That's a good suggestion.
If it only happened on a trip, it could just be the balance is thrown off again.
If you had a motor mount issue, it would do more than vibrate it would also make a metal to metal sound of the engine bouncing on the mount with a bad rubber.
Ray
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 12-11-2012, 09:50 AM   #8
bluedevil03
Fan#: 106558
You would be surprised how many ppl throw weights after they get new tires or the tires have excessive road force and have to be rebalanced.
Old 12-11-2012, 12:19 PM   #9
SD_Rider
SD_Rider's Avatar
Fan#: 103846
What I Drive: 2002 Blue SVT
FF Reputation: 1 SD_Rider Good Standing Member
Just recently happened to me on my Pathfinder. The days of the stick-on wheel weights...
2002 Ford Focus SVT 125k
1996 Nissan Pathfinder 250k
2001 Suzuki Marauder VZ800 9.5k
SD_Rider is offline
Old 12-11-2012, 03:36 PM   #10
apagios
apagios's Avatar
Fan#: 40891
What I Drive: '03 ZX5 SVT, '05 Mazdaspeed Miata
Points 873, Level 15
Points: 873, Level: 15 Points: 873, Level: 15 Points: 873, Level: 15
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 3 apagios Good Standing Member
a Roadforce balance will tell you if you have a bent wheel too.
I had a wheel on the Miata get bent such that the face of the wheel was no longer parallel with the flat part of the wheel that mounts to the hub. Basically it looked round to the naked eye, but threw up like 50 lbs of road force! A rim shop was able to pull it straight/true for me, now only reads a 4 lb road force.
apagios is offline
