Wheels and Tires for 2013 Focus Sedan - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 12-08-2012, 10:42 PM   #1
Broffermoon
Fan#: 106576
What I Drive: 2013 Silver S
Points 38, Level 1
Points: 38, Level: 1 Points: 38, Level: 1 Points: 38, Level: 1
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 Broffermoon Good Standing Member
Will 17" wheels and 245/45R17 tires fit w/o rubbing on a "Plain Jane" Focus s?
I am new to this site, and do not know much about the focus. Went on Tire Rack and no problem messages came up. Anyone done this on the "13?
Broffermoon is offline
Old 12-09-2012, 05:08 PM   #2
84Camaro_L69
Fan#: 105844
What I Drive: 2012 Diamond Tri Coat White SEL HB
FF Reputation: 1 84Camaro_L69 Good Standing Member
Ford usually makes all the cars universal (easy swaps for major parts), but I was wondering the same thing and want to ensure I get the answer when you do.
If you're using a wheel and tire combination with the same backspacing and offset as the factory wheels then you should be okay. Do you have any more details that could help someone who knows more than me with your question?
Stock with factory Sony 10-speaker HD stereo and 4-wheel disc brakes.
84Camaro_L69 is offline
Old 12-09-2012, 08:24 PM   #3
Broffermoon
Fan#: 106576
Points 38, Level 1
offset is 45, according to TireRack, the same. Backspacing is a new term to me, what is that?
Old 12-09-2012, 08:43 PM   #4
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
Backspacing is the opposite of offset. It's how far the back portion of the wheel is from the cener line on the hub.
The stock size is 215/50/17, right?
If that's the case than a 245/45/17 would be fine as long as you're planning to run a wider wheel to match it. I wouldn't suggest anything narrower than a 8" wheel
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
Old 12-12-2012, 09:04 AM   #5
Broffermoon
Fan#: 106576
Points 38, Level 1
Sorry, been away from the computer. When I sold my 2005 GTO I had an extra set of tires on wheels. The wheels are 45 offset and 6.05 backspacing. Currently the stripped down version of the focus has 15", 195R50X15. All my research says that the wheels and tires from the GTO will probably fit IF the bolt pattern is correct. The wheel is an aftermarket with multiple holes for different fitment. If I am lucky, they might fit, if not then I will have to decide if I will purchase new wheels. Any thoughts.
EARL
Old 12-12-2012, 09:18 AM   #6
sailor
Crankshaft
sailor's Avatar
Fan#: 57268
Points 11,780, Level 71
Points: 11,780, Level: 71 Points: 11,780, Level: 71 Points: 11,780, Level: 71
Level Up 33% Completed
Forum Activity 99%
Sounds good so far, the bolt pattern is an "odd" one at 5x108, older Focus was 4x108 - also "odd".
Tire size, to see if the overall diameter is close enough is the next issue.
Luck!
sailor is offline
Old 12-12-2012, 09:32 AM   #7
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 33,731, Level 100
Points: 33,731, Level: 100 Points: 33,731, Level: 100 Points: 33,731, Level: 100
Level Up 0% Completed
Forum Activity 5%
After a quick search the gto runs a 5x120 lug pattern not the same as the focus.
But the obvious answer if you have the focus and the old wheels the best thing to do is test fit the wheel. If it don't fit it don't fit. You can't put it on then find out the wheel is off while your driving, it just won't fit.
Sent from FBI surveillance van 2
TheGlassMaker is offline
Old 12-12-2012, 04:07 PM   #8
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,359, Level 47
Points: 5,359, Level: 47 Points: 5,359, Level: 47 Points: 5,359, Level: 47
Level Up 5% Completed
Forum Activity 5%
FF Reputation: 35 thenorm Great Standing Member
not quite...
off set can be positive or negative. measure from the centreline of the wheel.
ie. most FWD car wheels are negative offset, while deep dish wheels for RWD cars can be positive offset.
Backspacing is total distance from the hub face of the wheel to the lip of the wheel (ie. if you put a straight edge spanning accross the back of the wheel)
i agree a 8" wide wheel is needed.
245/45R17 might be too tall. maybe consider a 40 series. confirm with a online tire size calculator (google it).
Also, the wheel offset is going to need to be perfect, so you dont rub too bad
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 12-12-2012, 04:27 PM   #9
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 7,723, Level 58
Points: 7,723, Level: 58 Points: 7,723, Level: 58 Points: 7,723, Level: 58
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 12%
FF Reputation: 11 Joeywhat Great Standing Member
Also need to make sure the hub size is correct between the GTO wheels and your Focus.
Hatch Nation #29
Joeywhat is online now
Old 12-13-2012, 04:13 PM   #10
Julian@TireRack.com
FF Affiliate
Fan#: 102247
What I Drive: N/A
FF Reputation: 2 Julian@TireRack.com Good Standing Member
This page is the best way to take a quick look at offset and backspacing. Offset Explained
As for if a 245/45R17 will fit, depending on the tire the rim width range is anythere from 7.5" to 9". The wheels we have listed on our website are all a garunteed fitment. Our techs measure vehicles with some high tech laser/cad system and take those drawings and match up what wheels will fit. To find out if another wheel will fit compering offsets and widths will help, but there's no other way then to try it and see.
888-428-8355 ext. 4798
Julian@TireRack.com
Remember to reference Julian/Focus Fanatics in the "previous contacts" field to make sure the forum get's credit!
Julian@TireRack.com is offline
