Front of car vibrates when clutch disengaged - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-08-2012, 05:28 PM   #1
stromberg2
Fan#: 57480
What I Drive: 2003 Red SVT
Points 281, Level 5
Points: 281, Level: 5 Points: 281, Level: 5 Points: 281, Level: 5
Level Up 62% Completed
FF Reputation: 1 stromberg2 Good Standing Member
Hey guys, I've got a weird problem. First off, I need new wheel bearings on front passenger wheel. Here's the weird part...when I disengage the clutch, the front of car has a weird vibration, like the wheel bearing noise, but accelerated. When clutch pushed in, it goes away. Any ideas? Dog bone, vacuum leak?
Thanks,
Stromberg2
stromberg2 is offline
Old 12-10-2012, 10:33 PM   #2
StephenElsbree1986
StephenElsbree1986's Avatar
Fan#: 104271
What I Drive: CD Silver 2003 SVT
Points 1,167, Level 18
Points: 1,167, Level: 18 Points: 1,167, Level: 18 Points: 1,167, Level: 18
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 1 StephenElsbree1986 Good Standing Member
Vacuum leak on your clutch....? How many miles on your car? When was the clutch replaced? What Flywheel do you have, but like in any manual car rattling/chatter will be your Retaining Bearing and Slave Cylinder one piece unit in the SVT, Alum FW will chatter also, but that normal for lightweight fw
StephenElsbree1986 is offline
Old 12-11-2012, 07:46 AM   #3
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
Level Up 0% Completed
FF Reputation: 34 tukaniSVT Great Standing Member
Hmm. I would start with the Motor mounts. Check to see if the rubber on the mounts are still good.
Then start checking for the vacuum leak. But on the clutch ... hmm.
Is the vibration only when the car is moving? And does it become even worst when you accelerate?
If it's when you accelerate, could be a few things. New to balance your tires, need an alignment, bad bearing (as you stated) or bad tie-rods.
Ray
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 12-11-2012, 11:27 AM   #4
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
Its in the clutch bro. Engine mounts wont cause viberation when the clutch is engaged or disengaged, So its the ToB unit or possibly the Clutch Fork, if it rattles horribly
Ray
Old 12-11-2012, 05:47 PM   #5
stromberg2
Fan#: 57480
Points 281, Level 5
Thanks guys, I'll check it out. I'm leaning towards a bad bearing, as there is a drone from front passenger side wheel.
Stromberg2
Old 12-13-2012, 05:59 PM   #6
stromberg2
Fan#: 57480
Points 281, Level 5
Ok, I described the problem a bit wrong. What happens is the car's right front wheel, on acceleration, has a clunking sound, like the tire is low or it's loose on the hub. The sound and feeling go away when I let up on the gas. Hit the gas, and it's clunking again. Like I said before, I know I need new bearings, and I could live with that, but the clunking could be dangerous. HHHEEELLLPPP!!
Stromberg2
Old 12-14-2012, 12:40 PM   #7
nate4027
Fan#: 105354
What I Drive: 2003 Competition Orange Svt
FF Reputation: 1 nate4027 Good Standing Member
Sure it's not a cv joint?
nate4027 is offline
Old 12-14-2012, 01:03 PM   #8
stromberg2
Fan#: 57480
Points 281, Level 5
No, I'm not sure. Weird thing is it comes and goes. Yesterday, it was horrible, today, not so bad.
Stromberg2
Old 12-16-2012, 07:45 PM   #9
Continuous
Continuous's Avatar
Fan#: 84970
What I Drive: 2004 SVT ZX3 Infra-Red
Points 1,035, Level 17
Points: 1,035, Level: 17 Points: 1,035, Level: 17 Points: 1,035, Level: 17
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 1 Continuous Good Standing Member
Judging by the problems your are saying you're having I'd have to agree that the noice you are hearing is a throw-out bearing on your clutch fork.
Infra-Red SVT ZX3
Continuous is offline
Old 12-17-2012, 02:34 PM   #10
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
I'm still confused you said you need a wheel bearing and you havnt fix that yet, I'm confused BC since you said it's the wheel it's the bearing...... Jack up your car if the wheel give when you pull out it's the bearing if it isn't is what I said before since you Sid it was clutch pedal related
