Traction Control and loud noises? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-09-2012, 11:45 AM   #11
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,045, Level 66
Points: 10,045, Level: 66 Points: 10,045, Level: 66 Points: 10,045, Level: 66
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 24%
Originally Posted by BetaDnB View Post
Doesn't the traction control system work by utilizing the ABS?
Technically the original systems worked only based on the ABS, but the newer systems also integrate throttle control now that the car is drive by wire and can reduce the engine performance/ throttle response as well to prevent wheel spin after it catches it.
I've still been able to get it to chirp the tires before it catches them at times on wet pavement or going around a corner at low speeds.
suss6052 is online now
Old 12-09-2012, 12:06 PM   #12
BaconZombie
BaconZombie's Avatar
Fan#: 98205
What I Drive: 2013 VW GTi, United Grey
Points 813, Level 15
Points: 813, Level: 15 Points: 813, Level: 15 Points: 813, Level: 15
Level Up 13% Completed
FF Reputation: 3 BaconZombie Good Standing Member
It's wheel hop and engine movement. One of the biggest issues from the factory with our cars is the squishy engine mounts that allow a massive amount of engine movement to provide a smoother ride with less vibrations. Upgrading the rear engine mount is one of the easiest and cheapest mods a lot of us has done. It helps with the wheel hop and engine movement, but not drastically. I'm still waiting (nay, hoping) that someone comes out with a full set of engine mount inserts for our cars, like what I have for my '03 SpecV. That helped tremendously with these issues, but does transfer a bit more vibration to the cabin, especially via the shifter (if you have a manual), and the pedals.
Just be forewarned, while it's fairly uncommon, a lot of hard, repetitive beating on the engine mounts can make them fail, and fail hard.
BaconZombie is offline
Old 12-09-2012, 02:11 PM   #13
Firezapper
Fan#: 103367
What I Drive: 2012 5 door
Points 6, Level 1
Points: 6, Level: 1 Points: 6, Level: 1 Points: 6, Level: 1
Level Up 11% Completed
FF Reputation: 1 Firezapper Good Standing Member
Yes I have the same issue on wet roads. It only happens from a stop. It is the brakes grabbing as the TC engages. The speed a which the tires are spinning then the brakes trying to stop the spinning causes the violent thud. The wheels do not spin as easily on dry roads so not as violent when TC kicks in.
I'm wondering what will happen in snow. Same effect or not as violent.
Firezapper is offline
Old 12-09-2012, 03:16 PM   #14
a351must2
Fan#: 87762
What I Drive: 2012 Focus Ti, 2011 Mustang GT
FF Reputation: 1 a351must2 Good Standing Member
Dead on exactly what's happening ... for me it happens whether traction control is on or off. Common problem for anything with half way sticky tires and squishy engine or suspension mounts. Much easier to fix in rear wheel drive than front wheel drive, but stiffer engine mounts are usually the fix in FWD. With stiffer engine mounts comes more vibration and noise though.
2012 Focus Ti Hatch, Blue Candy
2011 Mustang GT, Grabber Blue, 6spd
1978 Mustang II, 351W, Tremec 3550
1978 Mustang II, 2.3L Turbo, 5spd
a351must2 is offline
