Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 01-12-2013, 12:33 PM   #11
meattooth
meattooth's Avatar
Fan#: 97031
What I Drive: 2012, candy blue, se hatchback
FF Reputation: 4 meattooth Good Standing Member
Originally Posted by lstat View Post
Before purchasing a Focus I had full intentions to go with a Mustang, the radio bezel I found looked fairly good but it wasnt Metra. I saw the Metra and immediately decided it would never go in my car, had to find an alternative!
I havent had the chance to see one in person, but everybody here on the forum says they are cheap and do not look good, all the more reason not to bother with them. I want something that looks OE, the Chinese eBay units looks like the only to achieve that without going all out and adding MFT, but they dont say anything about being compatible with Sirius so I am stuck at a brick wall there, to.
I found when upgrading my 6 speaker non touch stereo that I got a better signal to the amp from the front speakers. I tapped both and the rear speakers channels cut about 45hz and lower bass signals. So if it seems you're missing some bass that's probably why. My 09 F150 was the same way. Just FYI
2012 Focus SE hatchback sport, 203a, MTX-75, Candy Blue, Custom 2.5 Exhaust, K&N Typhoon.
Sonic Crew #012 E-123 Omega
meattooth is online now
Old 01-27-2013, 09:40 AM   #12
jayw32
Fan#: 103280
What I Drive: 12 sonic blue se
FF Reputation: 1 jayw32 Good Standing Member
anyone got pics on how to remove the door panel? or tips? i only saw one screw by the handle on the rear doors
jayw32 is offline
Old 01-27-2013, 09:48 AM   #13
meattooth
meattooth's Avatar
Fan#: 97031
http://www.focusfanatics.com/forum/showthread.php?t=276050
guide to changing speakers
Old 02-12-2013, 11:43 AM   #14
HoneyBadger
Fan#: 104860
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 HoneyBadger Good Standing Member
Dang that sounds like a pain. I will be adding in my 12inch sub..I should only have to tap into the 8inch sub I have in the back of the car. This should be a piece of cake. Has anyone used the fuse panel in the back of the car instead of running it up front?
HoneyBadger is offline
Old 02-12-2013, 01:17 PM   #15
TheDriver916
TheDriver916's Avatar
Fan#: 96977
What I Drive: 2012 Focus S Sedan
FF Reputation: 1 TheDriver916 Good Standing Member
It would be more of a pain to mess with fuse panel. Personally I wouldn't cut corners when your dealing your electronics. Just run everything to the battery and head unit (if you decide to add that) the conventional way.
2012 Sedan 5 spd. (Listed options; none)
NOT stock.
TheDriver916 is offline
Old 02-12-2013, 01:43 PM   #16
HoneyBadger
Fan#: 104860
Are you talking about having a stock aftermarket head unit?
My thoughts were to tap into the wires on the 8 inch sub, to connect to my amp. The amp would have a wire directly for power from the battery. The little blue wire (Tells the amp when the car is on), could be connected in the fuse panel in the back. When I say connect I am talking about adding a second fuse to the one. I just don't know if any of them turns on with the car or not. I will need to get a diagram for it.
Old 02-12-2013, 01:44 PM   #17
meattooth
meattooth's Avatar
Fan#: 97031
Seat heater fuses in the hatch work with the key on and off for remote.
Old 02-14-2013, 09:00 AM   #18
HoneyBadger
Fan#: 104860
Yes, I just need to find a diagram or just start pulling fuses to see which one does what. This will make my Sub install super easy.
Old 02-16-2013, 07:12 PM   #19
HoneyBadger
Fan#: 104860
Originally Posted by calvin.lehman View Post
I added subs and amp in my 2012 focus. I used the converter on my rear speakers by taking out the seal molding along the bottom of the rear door opening and tapped into the rear speakers then ran a ground wire inside the trunk and the power wire through the firewall to the battery... the remote wire was ran to the fuse box under the glove compartment and used an add a circuit that had a wire tap and tapped into something that turned on with the key
Where exactly did you find the hole in the firewall for the cable? Was it with all the other cables going in on the passenger side?
Old 02-17-2013, 04:00 PM   #20
OPsDad
OPsDad's Avatar
Fan#: 108661
What I Drive: 2x2013-TI4drPlat'mNAV,SE5drSterling
FF Reputation: 2 OPsDad Good Standing Member
fuses
There is a fuse diagram in the owner's manual with what each fuse does.
SR #265 | "Quia currus certatus, inferius"
13 Focus Ti Sedan w/Handling Pkg, MFT Sony 10 NAV, Leather
13 Focus SE HB Sterling Grey, 201A, Leather
06 F350 6.0L DRW King Ranch, Sunroof, Rhino Bed Liner, 4" MBRP Turbo Back, AirRaid, Edge Chip w/Pyro
OPsDad is offline
