#1 | ||||
Ford F150 Brakes
Hey guys,
So i have been working on my grandfathers 1997 ford f150 with a 4.6L V8 in it. He gave it to me and asked me to check out why the brakes were "soft" Well the front needed pads and rotors so i did that. The brakes were still soft so continued to bleed them. After that i replaced the master cylinder, brakes got better. Then the caliper on the passenger side decided to lock up. So i replaced both calipers on driver and passenger side bled them again. I had no peddle at all. So i figured maybe the master cylinder went bad, decided to replace it again. So after all of that i bled it again still no air. But now when the car is off the peddle will get harder after about 4 or 5 pumps. Then wait a second and it loses pressure again. I cannot find any leaks and at a complete loss. So i have replaced both front calipers, rubber lines, master cylinder, and there is no more air coming out of the bleeder valves. Any suggestions!? Thanks Mike
2004/2005 Ford Focus Saleen The cops are here to keep us safe.............I'm here to keep them busy! Hatch Nation #43 |
| Sponsored Links | |||
Advertisement | |||
#3 | ||||
FF's Night Security
Moved your thread so you could get some better help with your problem. Check the rear too, maybe it's got leaky wheel cylinders if it's got drum brakes?
I started out with nothing and I still have most of it left Hatch Nation #15 (Ole' Yeller') & #150 (The SVT) Moderator for Technical Chat Zetec Performance Chat Southern Fanatics Chat |
#4 | ||||
My soft pedal problem was fluid, but it sounds like you've changed all yours already. Mine was green when it came out. I had changed pads & rotors, but still had soft pedal. Then gravity bled all four corners, put new fluid in, and was good to go.
#449 of 1978 - Black on Black JRSC w/BBK, McNews's tune, ORP, K&N air, R3d_RovrZX3 3rd brake conversion w/blinkers, FRPP strut tower bar, cross drilled rotors, HPS pads, SS brake lines, lit door locks, Torsen LSD, Centerforce clutch & flywheel... |
#5 | ||||
I've removed the rear drums to check for leaks, and properly adjusted them, Also gone through about two bottles of fluid, after doing the correct bleeding order. farthest from master to closest.
The only things left i could think of is 1 there's a leak that i have no idea where it is. 2 the brake booster but i figured if that went the peddle would be hard.
#6 | ||||
Ive come to the conclusion that i think the booster is bad. Cause i can pump the brakes up, then it instantly loses pressure. What do you think
#7 | ||||
Try pinching (or disconnecting and plugging) the booster's vacuum line to see what that feels like. Bad booster, the pedal usually feels firm but there is not much line pressure output from the master cylinder. Bad master cyl is more common, but has several ways they can 'feel' when bad.
#8 | ||||
I disconnected and pinched the line nothing changed
| Thread Tools | |
| Display Modes | |
