Miss fire #4 after Timing belt - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-07-2012, 09:24 PM   #1
302N20
Fan#: 97177
What I Drive: 1995 Mustang GT
FF Reputation: 1 302N20 Good Standing Member
Okay, I've been reading up on the Timing Belt job for months, today I went and did it at my buddies shop. 81K on the car. Did a Timing Belt, Tensioner, idlers, Serp Belt, Serp Tensioner, oil change, fuel filter.
The car is bone stock besides a catback and short ram intake.
We did the job and started the car, miss-fire. Checked the timing 3 more times and it was all correct. Started it again, miss fire. Starting messing with the wires, took #4 on/off and then it started firing and running smooth. GREAT! Put the rest of the car back together.
Go to fire it up to leave, miss fire again. Had to get home at this point so limped it there assuming it was a bad plug wire. Got home and put new wires on it, all 4, and still miss fire. Checked for codes, only had miss fire of #4 which I expected.
The car had aftermarket wires and what looks to be a stock Motorcraft coil.
Did my coil just happen to go bad the same day I did my timing belt? Is there something I'm missing? Also I put new plugs in it 1,000 miles ago and those have been fine (motorcrafts).
1995 Mustang GT 410W|AFR 205s|10.8 C/R|Ed Curtis Custom Cam|Trickflor R Box Intake|T-56 Magnum
11.28 @ 123.42......10.36 @ 135.25 150 shot (so far)
2003 Focus SVT|ZX5|Infra-Red|Magnaflow catback
1998 Explorer XLT|174K & counting...
302N20 is offline
Old 12-08-2012, 01:19 PM   #2
302N20
Fan#: 97177
Changed the coil. Still miss fire
302N20 is offline
Old 12-08-2012, 08:24 PM   #3
DLQ001
Fan#: 80230
What I Drive: 2002 Silver Focus SVT
FF Reputation: 1 DLQ001 Good Standing Member
Might be worth checking the the rubber insulators between the two manifold pieces. You can see them right below the injectors. I had a #3 misfire. Easy way to check them is with water, you will hear the difference when the water hits the spot. Low water flow and one insulator at a time. Another way if the water doesn't work is with engine cleaner or starting fluid (flammable- be careful). I found mine with water, then used starting fluid to confirm the spot, and again to confirm the repair.
Bought the rubber from the local Goodyear Rubber dealer, got them and had them installed the same day. 2" ID if I remember, 12 inch length is all you will need.
DLQ001 is offline
Old 12-08-2012, 11:38 PM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,525, Level 100
Points: 52,525, Level: 100 Points: 52,525, Level: 100 Points: 52,525, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
The coil wire plug in is bad to be bad
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
