#1 | ||||
Removing the flex pipe and cat all in one piece?
Hey,
I was wondering if it was possible to remove the cat and flex pipe still bolted to eachother? I don't have the means to get up to the bolts attaching the cat and flex pipe together. Thanks! |
| Sponsored Links | |||
Advertisement | |||
#2 | ||||
I took mine out together. But I have an 06, not sure that it would be much different.
2006 Focus ZX3 SAP, Draxas Header, FS Werks Flex pipe, MBRP exhaust, CAI, Tuned, Debaged, tinted windows, FRPP lowering kit, SVT 5-spoke wheels, Black Halo Projector Headlights, Niteshaded Side markers and tails, Mazda rear wiper, mustang antenna. |
#3 | ||||
FF's Night Security
It's a lot different. I doubt you could get them out together but you can always try. I had a pain just getting the cat up into position.
I started out with nothing and I still have most of it left Hatch Nation #15 (Ole' Yeller') & #150 (The SVT) Moderator for Technical Chat Zetec Performance Chat Southern Fanatics Chat |
#4 | ||||
If you can't, how the hell do you get up there to the bolts??
#5 | ||||
FF's Night Security
Use extensions to get to it, makes it easily reachable.
#6 | ||||
Well let's hope the bolts aren't all seized up. Although since it's doesn't really snow up here and there's no salt on the road, it should be too bad.
While I'm here, what kind/length of extension did you use? Do you remember the socket size? It's just so that I have all I need for when I attempt this. |
#7 | ||||
FF's Night Security
I want to say I needed to use two extensions together but I can't remember. I definitely don't remember what size bolts they were lol. What ever the cat's bolts are is probably what size they'll be.
#8 | ||||
Imo not possible. The cat alone is a bitch to remove, the heat shield and sensors are always in the way of something, and if u pull everything though the front im not sure the flex pipes bends will make it possible. gl trying to remove the sensors with the cat pipe still in. 2 days ago I installed my catpipe back in for inspection and my shoulder and neck are still sored
Youll need a +12" extension and a pretty long tq bar to tq it out, and some chuck norris strenght. Soak the bolts in pb the night before and again like 30 mim before trying it. I used a 16" extension if a remember correctly (autozone, like $10) |
#9 | ||||
Ah ok thanks... good to know about the extensions. Yup, it's going to be a pain but I'll try anyway.
#10 | ||||
If you have access to a lift its not a pain at all, also if you got power tools it makes life easier, When I had to remove rear O2 sensor, I did it in my shop class and to remove flex from cat just held a box end wrench on back and then took air ratchet with an extension and bitch came right off. If you cant get to a lift it's still possible to, just a little more challenging, if no power tools get sum PB blaster or sum type of penetrating oil on there b4 wrenching at it. overall really easy task, if you ask me tho, everyone is different when it comes to this stuff.
| Thread Tools | |
| Display Modes | |
