Oil cooler? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-06-2012, 04:19 PM   #1
IH84DZ
Fan#: 101801
What I Drive: 03 CD silver SVT 5 door
FF Reputation: 5 IH84DZ Good Standing Member
Oil cooler?
So this summer I had a wicked power steering rack leak. The RH seal was leaking but the RH boot is tight. So the fluid ran down the transfer tube to the LH side where the boot leaks and dripped all over.
The leak has since gone away completely. I'm convinced it was due to high PS temps because my header heat shield is missing and that tube (can't remember if supply or return) runs directly over that super hot header....
Anyhow, I've recently noticed a few drops of coolant on the ground on the RH side of the engine compartment. Last oil change I noticed a drip of coolant on the RH halfshaft boot.
But, when I warm the engine up and pressurize the cooling system with a tester not only does the pressure not drop but I can't see a leak anywhere....just the signs that a leak exists (drips on halfshaft boot).
I've heard the oil coolers on these can leak and it makes sense because of how the hoses are sorta in the way of the oil filter...
But I've also heard they are discontinued? I'll keep trying to find the leak with conventional methods but just looking for info about the failure rate and part availability in the meantime
IH84DZ is offline
Old 12-06-2012, 10:54 PM   #2
dneedham
Fan#: 78466
What I Drive: 2003 CD Silver ZX5 SVT
Points 392, Level 7
Points: 392, Level: 7 Points: 392, Level: 7 Points: 392, Level: 7
Level Up 84% Completed
FF Reputation: 1 dneedham Good Standing Member
Please verify fit before purchase, but it looks like you can purchase it here: http://www.fordpartsgiant.com/Page_P...te=&isvinskip=
Good luck
Darren Needham
Andover, Ks.
2003 Focus ZX5 SVT (CD Silver) 132k
1988 Merkur Scorpio (Raven) 84k "restoration project"
dneedham is offline
Old 12-07-2012, 08:06 AM   #3
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,235, Level 41
Points: 4,235, Level: 41 Points: 4,235, Level: 41 Points: 4,235, Level: 41
Level Up 43% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
I've heard of people using an oil cooler from an escape and rigging it up. I believe the metal elbows on the cooler rust thru causing leak. there is a tutorial on fj.com to make the escape cooler work, might need to add some fittings.
Or contact Steve at tousley ford and he will be able to get you what you need. I also heard the cooler is discontinued.
I now drive a Japanese Ford.
macdiesel is offline
