2012/13 sub wiring? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-06-2012, 03:10 PM   #1
sk8parker94
sk8parker94's Avatar
Fan#: 103961
What I Drive: 2013 Oxford White ST
FF Reputation: 1 sk8parker94 Good Standing Member
2012/13 sub wiring?
I have a 2013 ST and Im trying to install an amp for 1 12" sub, but I can't for the life of me find a spot in the firewall for the power wire to go through (on the drivers side) has anyone with a 2012/13 focus installed a sub? If so how did you go through the firewall?
Thanks in advance!
sk8parker94 is offline
Old 12-06-2012, 07:07 PM   #2
mrpeaches
Fan#: 103895
What I Drive: 2012 White Focus SE Hatchback
FF Reputation: 1 mrpeaches Good Standing Member
I am assuming that the fire wall setup in the 13 ST is the same as all mk3 focii.
Your ST will not have a convenient place on the drivers side firewall to punch through because the place that some others on this forum have used is taken up by your clutch assembly.
I also have a manual transmission on my car, so I went through the main power feed grommet on the passenger side. Open your hood and look towards the rear of the engine bay. About 6 inches below the top of the compartment and about 6 inches to the right of the passenger side wall will be a rubber grommet with a cable wrap going through.
You will want to carefully make an "x" with a knife or razor on the side of the rubber grommet and push your amp power cable through. Do not take the easy way out and pull back the rubber grommet and slide the cable between it and the frame, as this will lead to the cable rubbing against the car frame and eventually wearing through the cable insulation and causing a short and possible fire.
Let me know if you have any other questions.
mrpeaches is offline
Old 12-06-2012, 10:05 PM   #3
sk8parker94
Fan#: 103961
I already ran the RCA and Signal turn on wires through the passenger side :(
I'll take a look at it! thanks!
Old 12-04-2013, 09:13 PM   #4
Djdylan
Fan#: 118839
What I Drive: 2012 Ford Focus SE Sedan
Points 8, Level 1
Points: 8, Level: 1 Points: 8, Level: 1 Points: 8, Level: 1
Level Up 15% Completed
FF Reputation: 1 Djdylan Good Standing Member
Hello,
For the signal turn on wire are you using the power antenna? (I believe yellow orange) From the passenger side middle console ?
Sent from my iPad using Tapatalk
Djdylan is offline
