Installed LEDs with resistors but have no parking light? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-07-2012, 03:19 AM   #11
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,073, Level 27
Points: 2,073, Level: 27 Points: 2,073, Level: 27 Points: 2,073, Level: 27
Level Up 49% Completed
Forum Activity 9%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
I have the same resistor rating on my rear bulbs and they function correctly. Maybe a lower resistor would work, but I'm thinking it's the bulbs.
Fox Hound: Liquid Stang - Sniper Focus - Decoy Escort (or was it a Tracer...)
Sniper Focus is online now
Old 12-07-2012, 03:24 AM   #12
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,547, Level 100
Points: 138,547, Level: 100 Points: 138,547, Level: 100 Points: 138,547, Level: 100
Level Up 0% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
Buy-Sell-Trade Rating: (11)
The blubs work fine without the resistors. I'm thinking since they have small capacitors on them make the resistors too strong. I'm not 100% on that though, it very well could be the bulbs.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 12-07-2012, 03:27 AM   #13
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
FF Reputation: 68 TerryB Excellent Standing Member
I don't know, those look fine to me. Maybe check the wiring ?
TerryB is offline
Old 12-07-2012, 03:35 AM   #14
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 60%
What wiring?
Moderator for
Technical Chat
Old 12-07-2012, 03:35 AM   #15
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 60%
I'm going to order the smaller of the resistors and see if that works. If not then I'm done with the LED's
Moderator for
Technical Chat
Old 12-07-2012, 03:53 AM   #16
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 60%
ok so now I'm looking at other load resistors and the cheap bastard in me is price shopping and I'm finding a few different ohm'ed resistors. I'm looking for a 25w which would be half of the one I got now but the one on Superbrightled.com is 25 ohm 25 watt. Wouldn't that be even more resistance being 25 ohm compared to the 50 watt 6 ohm one's I have now? Found on ebay 25 watt 6 ohm resistors. Which ones should I try?
Moderator for
Technical Chat
Old 12-07-2012, 05:32 AM   #17
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 60%
Well I just ordered some 25w 6ohm resistors and see how those work.
Moderator for
Technical Chat
Old 12-07-2012, 03:29 PM   #18
Sniper Focus
Fan#: 84221
Forum Activity 9%
The watt rating of the resistor is the size, the bigger the number the bigger the size and the more heat it can dissipate. The 50w size is marketed for the turn signals. The 25w 6ohms are the same ones you have now, except they're smaller...
The 25 ohms has more resistance; the lowest load resistor I've seen are 3 ohms. I still don't know if those would work for you either.
I was thinking check the wiring for the load resistors too, double check that you didn't wire them to the parking light wires.
Old 12-07-2012, 03:46 PM   #19
TerryB
TerryB's Avatar
Fan#: 34559
If they use a common ground, I can the problem. I changed my rear light set-up and run separate grounds for them.
TerryB is offline
Old 12-07-2012, 05:26 PM   #20
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 60%
I tried two different grounds. One in the back hatch area on the body plug and the other right by the tail light bulb. The first resistors I have were 50w 6ohm the ones I just got were 25w 6ohm. I was hesitant to get the 25w 25 ohm ones. There is also a 25w 10ohm ones as well. We'll see if these work when I get them
Moderator for
Technical Chat
