DURATEC Ti-VCT Performance (2012-2013) The place to chat about any Duratec 2.0L Ti-VCT engine performance, tuning and exhaust related upgrades.
#251 | ||||
That Guy
Getting a tune is about maximizing the engine's performance in the state it is currently in.
HN Member #161 *155 hp / 143 lb ft (DCT)* Moderator for- DURATEC Ti-VCT Performance (2012-2013) ST Performance (2013) MK3 Focus ST Focus Sonic's MK3 Crew |
#252 | ||||
Yep,especially with modern ECUs an intake and exhaust can alter fuel tables enough to actually hurt performance and/or MPGs.
'12 Focus Red Candy SE Sport 5 spd '99 Toyota 4Runner Sport '11 Subaru WRX STI Hatch |
#253 | ||||
I WILL correct you.
~~~~~~~~~~~~~~~~~~~~~~ <>< Sonic's Crew #015 "Werehog" --- HN005 April 2013 HOTM |
#254 | ||||
All I want is to be able to fully turn off the electronic nannies and enjoy driving the car myself. The more I get used to my 2012, the more irritated I become with the stability control sucking the fun out of the corners. It jumps in anytime there is even a hit of rear biased yaw.
Rich aka Dr. Bilkenstein, the three footed hobbit Rally Revolution #21 |
#255 | ||||
I do want a tune for my Focus but for better power/mpg with bolt-ons. Its not required to toggle off the traction control. Similarly I'm sure abs can be toggled off either in the menu or by fuse pull. |
#256 | ||||
ABS cannot be toggled off. I actually don't want that to be taken away as it works very well on my 2001 and I assume that Ford has not taken a step backwards in that regard. Fundamentally, I only want the brakes applied when I hit the brake pedal.
#257 | ||||
I agree that it should be your choice but unless an LSD option becomes available for the MK3 I'm quite happy to have the electronics there. Even the Focus ST even uses electronic torque vectoring in leau of a proper LSD (which is quite stupid on fords part). Open diff's are generally crappy for handling and disabling the electronics on open diff FWD usually results in epicly useless levels of understeer. Disabling stability and traction control on a rwd or awd is always a more fun. When set my adjustable swaybars to the stiffest setting and lock the electronic center diff on my wrx to 50/50 power bias its always a thrashing good time. I believe it gives people the idea it would be fun on a fwd lacking LSD. In my personal experience I've found that opinion to be generally wrong. Regardless, there is no way of knowing if a tuning option for the MK3 would allow for the adjustment or toggling of the traction and stability systems in the focus. |
#258 | ||||
* - which is not much in comparison to others but sufficient to be informed
#260 | ||||
I love the stability control on the Focus, it's great. I can give it a bit extra throttle in a corner and it kills the understeer and whips around nicely, sometimes I can even get it to step the tail out, but I do have lowering springs.
Maybe you have to tweak you suspension a bit and learn how to drive a car that basically has computer controlled cutting brakes? I know technology is scary, but it's actually pretty cool when you put down the pitchforks and start to get to know it.
2012 Focus SE Hatch 5spd sport package, Tuxedo Black Metallic Road Magnet springs, custom CAI in the works, and fuzzy dice on the mirror |
| Thread Tools | |
| Display Modes | |
