LED experts chime in - Focus Fanatics
Go Back   Focus Fanatics > Model Specific Discussions > MK1 Focus
Old 12-04-2012, 06:57 PM   #1
mr1mrwun
Fan#: 94331
What I Drive: '02 Gold SE
FF Reputation: 1 mr1mrwun Good Standing Member
I'm planning on doing a full custom LED install on my exterior lights. I don't want to change the flasher relay mainly cuz I like the hyper flash.
My question is would having the stock relay constantly hyper flashing due to the lack of resistance cause the relay to fail prematurely?
mr1mrwun is offline
Old 12-04-2012, 09:06 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 46 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
I've yet to see a single flasher fail yet with stock bulbs. So based on that I'm going to say, no. It will outlast the car.
Don't "think outside the box".
There is no box.
iminhell is offline
Old 12-05-2012, 12:09 AM   #3
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
FF Reputation: 4 calebstubstad Good Standing Member
noob question: what is hyperflash? everyone talks about it and idk what it is lol
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 12-05-2012, 11:22 AM   #4
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
FF Reputation: 34 FocusedSlayer Great Standing Member
Its when people use an LED bulb without a resistor , and it looks like a light is flashing really fast instead of a slower pace like there suppose too.
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is offline
Old 12-05-2012, 06:07 PM   #5
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
FF Reputation: 77 S0C0nFused Excellent Standing Member
Do the 1st gen models actually have a relay? My 07 does not. I did not think turn signal relays had been used for decades. To answer your question, this must be determined. Remember though, in electrical/electronics, there is no 'free lunch'.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 12-05-2012, 07:32 PM   #6
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
FF Reputation: 20 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
The GEM handles the blink function if I'm not mistaken, and there's a little speaker that makes the sound in the steering column.
Most of my exterior is LED and I have resistors on the blinker circuit. Then I found out that the GEM doesn't like having little resistance to the running light circuit. With no resistance in the running light circuit the blinkers didn't work correctly, the opposite side would blink faintly. Plus with the hazards the door chime would beep and the interior lights would flash. So I added small load resistors on the running light side to fix it.
You might be able to not add resistors to the blinkers, but won't get away without having any resistors at all; at least with out a lot of annoying problems.
'03 SVT EAP "Eurotrish Bennett"
Sniper Focus is online now
Old 12-05-2012, 10:18 PM   #7
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What Sniper Focus said. Without any resistance in series, you have a 'run away' condition. feedback issues etc. The flasher driver is designed for incandescent. AS you wanted a "LED expert", to achieve a high flash rate, you need an LED interface circuit that 1: provides the required resistance for the OEM flasher circuit. 2: A timer (async) that produces X 'flashes' per second. 3: adjustable LED driver output section (so you can adjust based on LED specs which can change). I would suggest (rough assumption) not to exceed 2-3 flashes per second.
Old 12-06-2012, 09:05 PM   #8
mr1mrwun
Fan#: 94331
Okay, maybe I worded it wrong. I've been doing research on how to correctly plan out and make an array of LEDs. Not planning on using bulbs but making my own custom setup inside the light housings. So I know resistors are needed in the circuits for the LEDs to work properly to begin with. Also from my research I found out that just a LED bulb swap makes the GEM (thanks for that) think that the lights are not working/burnt out, hence the hyper flash, because of the missing resistance from what used to be incandescent bulbs. So when I do this will the GEM's life be diminished because of the state it will be put in?
Thanks for that info. Gonna have to look into that LED control interface. Would you have any suggestions for me to start looking in the right direction?
mr1mrwun is offline
Old 12-10-2012, 05:03 PM   #9
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
OK. I have tried to find the more advanced kits for you. They apparently no longer exist. The closest one I could find is here
http://www.mtmscientific.com/timer.html
You would need to reengineer the output (relay not suitable),timing cycles etc. I was trying to find the dual timer brds but no luck. I wanted to stay with a 555 as they can drive a power trans directly.
Old 12-11-2012, 05:04 PM   #10
mr1mrwun
Fan#: 94331
Thanks for that.
Pardon my ignorance, like I said I'm still learning about LEDs and small circuits, but is that timer a standalone or would I just need integrate it into the car's flasher circuit past the GEM? Or is it something I can/should put on the bread board for each separate array?
Both you and the description says it's a kit. So some searching on DIY electronics forums are in order. Still have a lot of research and learning to do!
Btw, whats a brd?
mr1mrwun is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
