Funny smell from engine bay... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-04-2012, 06:14 PM   #1
Vrod21
Vrod21's Avatar
Fan#: 86456
What I Drive: 2012 Tuxedo black metallic SE
FF Reputation: 3 Vrod21 Good Standing Member
Hey, does anyone know what this new orange coolant smells like when it's burning?
My coolant level is about an inch below the MIN line but I can't find a leak anywhere.
Going to the dealer tomorrow for them to check it out.
Vrod21 is offline
Old 12-04-2012, 07:28 PM   #2
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,291, Level 28
Points: 2,291, Level: 28 Points: 2,291, Level: 28 Points: 2,291, Level: 28
Level Up 94% Completed
Forum Activity 3%
FF Reputation: 13 BetaDnB Great Standing Member
Ţake a look at your reservoir again. The left side of it had this shelf thing going on. You might find the rest of the coolant in that area. Can you describe the smell? Is your passenger side carpet wet?
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
Old 12-04-2012, 08:47 PM   #3
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 953, Level 16
Points: 953, Level: 16 Points: 953, Level: 16 Points: 953, Level: 16
Level Up 53% Completed
FF Reputation: 5 dbenney Good Standing Member
all coolant, green yellow or orange smell the same... kind of a sweet smell. any white smoke from the tailpipe?
dbenney is offline
Old 12-04-2012, 09:10 PM   #4
Vrod21
Vrod21's Avatar
Fan#: 86456
Hmm, it's not trapped in the reservoir. No white smoke and its definitely doesn't smell sweet.
It smells like burning chemicals (best way I can describe it)
I assumed it was coolant burning because it is low now.
I guess we'll see, or I'm expecting be be told its normal...that's happened enough around here.
Vrod21 is offline
Old 12-05-2012, 10:07 AM   #5
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,426, Level 97
Points: 26,426, Level: 97 Points: 26,426, Level: 97 Points: 26,426, Level: 97
Level Up 8% Completed
FF Reputation: 9 TORQUERULES Good Standing Member
DCT clutches?
TORQUERULES is offline
Old 12-05-2012, 12:09 PM   #6
Kaaru
Kaaru's Avatar
Fan#: 96763
What I Drive: '12 Oxford Wh. SEL Sedan 28/07/2011
FF Reputation: 1 Kaaru Good Standing Member
Humm, have the engine running and take a look at the engine bay. You will see on the left side (while facing your car) 2 circular selenoids that are aligned to the cylinder heads. Those solenoids are equiped with ''O ring'' type of seals. If any of those 2 solenoids are leaking you see engine oil leaking/gushing/spraying etc from those.
I had this issue back in nov 2011 and a faulty VCS (Variable cam Solenoid) was causing some engine oil to spray on the enigine. the smell was very, very bad as you can imagine. Do you see any kind of fluids on top of the engine ?
2012 Oxford White SEL Sedan
303A + winter package + Moonroof + 16'' OEM
Kaaru is offline
Old 12-05-2012, 02:57 PM   #7
Vrod21
Vrod21's Avatar
Fan#: 86456
No fluid on the engine. I know the solenoids your talking about and they are fine.
If I have it running with the hood open, I can smell it pretty bad from the right side of the engine. Behind the throttle body, right on the engine and left of the battery. Just above the transmission.
I had a coolant leak about 10k ago and it leaked onto the top of the tranny. No real smell with that leak thought but this smell is coming from that area.
Vrod21 is offline
Old 12-05-2012, 05:01 PM   #8
Vrod21
Vrod21's Avatar
Fan#: 86456
Strike 4 for Ford. There was a radiator leak. They are putting a new radiator in now.
As stated at the beginning this is the 4th thing to go wrong. Geez.
Oh and the dealer said they smelled it and it was not coolant. They don't know what the smell is. They will power wash the engine compartment and see if it comes back.
Vrod21 is offline
Old 12-05-2012, 07:15 PM   #9
Vrod21
Vrod21's Avatar
Fan#: 86456
Going to get the Focus now. Pretty disappointed in this things build quality.
Vrod21 is offline
Old 12-05-2012, 09:06 PM   #10
Vrod21
Vrod21's Avatar
Fan#: 86456
New radiator installed. They had to replace the refrigerant for some reason. Still has the funky smell though...
Vrod21 is offline
