disciplerocks's FF13 build thread - 5.0 pron inside - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-27-2013, 08:40 PM   #51
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
Points 13,185, Level 74
Points: 13,185, Level: 74 Points: 13,185, Level: 74 Points: 13,185, Level: 74
Level Up 84% Completed
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
Got the clutch line modified today for the external slave.
04 ZX3 Mostly Stock ["Best Non-SVT" FITF '12][3/13 ROTM][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 04-03-2013, 07:43 PM   #52
disciplerocks
Fan#: 59330
Installed slave and line. All I need is a union and that will be done.
Copper plugs. Previous owner used the same.
Explorer TB vs SN95. Need to find out how to mod it.
Angle not quite right.
Stainless steel hardware and Massive plug wires.
Old 04-03-2013, 08:24 PM   #53
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,459, Level 100
Points: 35,459, Level: 100 Points: 35,459, Level: 100 Points: 35,459, Level: 100
Level Up 0% Completed
Forum Activity 5%
I those same type of copper plugs in my spi. I liked them.
Nice to see some progress, I hope to get moving on my by the end of the month.
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is online now
Old 04-03-2013, 10:40 PM   #54
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
Looking great Dustin!
Hatch Nation #8
September 2012 Ride of the Month
katiekay is online now
Old 04-04-2013, 10:14 PM   #55
disciplerocks
Fan#: 59330
Today I permanently mounted the AC bracket, permanently ran fuel lines in the engine bay, and started messing with the TB. Swapped over the IAC and swapped the TPS from my truck. Also tried to cut and weld the tab on the opposite side, but apparently the spring is on a plastic spacer and it melted it to the spring. Oops, now for plan B. But I don't know what that is yet.
SN95, Explorer, and Ranger TPS
Old 04-05-2013, 09:44 PM   #56
disciplerocks
Fan#: 59330
Removed the intake and finished up all the vacuum lines. Also removed the TB spacer and installed the throttle cable. Getting pretty close to having the engine bay all wrapped up.
Old 04-06-2013, 06:15 PM   #57
disciplerocks
Fan#: 59330
So I spent my afternoon trying to figure out why it won't run. It will try and stumble and die. It will run for a second if I add starting fluid. It will run for a second if I cover half of the MAF housing. When it does run it sounds like its sucking too much air and its choking, but it won't even try with the throttle open.
The only thing that is different is that I swapped out the SN95 intake for the Foxbody and Explorer TB.
Old 04-06-2013, 06:57 PM   #58
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,637, Level 94
Points: 23,637, Level: 94 Points: 23,637, Level: 94 Points: 23,637, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
how did you work out the issue with your TPS? Think that might be an issue? I remember it seemed to run better awhile back?
I see your alternator bracket and PS pump brackets have pulleys on them...
how bout the throttle cable though. isn't that a snap in deal?
mikebontoft is online now
Old 04-06-2013, 07:42 PM   #59
disciplerocks
Fan#: 59330
I tried 2 different TPS sensors. I think its a vacuum leak.
Old 04-06-2013, 07:52 PM   #60
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 16%
I guess yours doesn't have an idle up valve, but I totally just noticed that the throttle linkage is supposed to face down towards the valve cover.
I agree though.... it sounds like it's a vacuum leak. stick a tennis ball or something over the intake and spray around the manifold and stuff if it will run that way.
