Shuts off when hitting bumps... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-04-2012, 05:05 PM   #1
Ill tempered Ian
Fan#: 57017
What I Drive: 2000 Blue ZX3
FF Reputation: 1 Ill tempered Ian Good Standing Member
I have searched around only to find similar issues with missing symptoms. I have a 2000 ZX3 and last night while in transit I hit a bump causing the engine to shut off completely. The gauges also reset and instrument lights lit up. It did not reset the time and the radio stayed on. Coasted to a stop turned the key and she started right back up... Continued my commute only to hit another bump and again, shuts off immediately, no hesitation, surges or sputtering. I opened the hood and jiggled around battery wires and checked the grounds, all seem to be in good order. Started it up and she ran fine for a while. Turning into my neighborhood I hit one last bump and again she dies. All other similar issues seem to be upon breaking or decelerating, this happens to me regardless of accelerating or decelerating if I hit a bump. CEL is on with no codes detected. Any suggestions on where to start tomorrow?
Thanks in advance!!
Ill tempered Ian is offline
Old 12-04-2012, 05:08 PM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,359, Level 100
Points: 138,359, Level: 100 Points: 138,359, Level: 100 Points: 138,359, Level: 100
Level Up 0% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
Sounds like a bad power wire. Also take off and clean your terminals you never know they may look good but not making good contact. The power wire comes off of the alternator, then goes to the starter and then to the battery. Mine never shut off when hitting a bump but the gauges resetting and a bump causing it makes think right away a power wire issue. My wire got so hot it melted the insulation, that could have happened to yours and now when you hit a bump it shorts out or that's what I'm thinking?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 12-04-2012, 05:14 PM   #3
Ill tempered Ian
Fan#: 57017
That kind of my guess well. I'm assuming your car to be a manual tranny which may explain why it wouldn't actually shut off. Thanks for the advice, that's where I will start. If anyone has something to add I would most appreciate it!
Thanks again sleepy!
Old 12-04-2012, 05:40 PM   #4
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,057, Level 79
Points: 15,057, Level: 79 Points: 15,057, Level: 79 Points: 15,057, Level: 79
Level Up 42% Completed
Forum Activity 3%
FF Reputation: 17 BLRich1 Great Standing Member
Buy-Sell-Trade Rating: (6)
Check the pig tail that plugs into the alternator. Those wires are known to break or pull out. Perhaps when you hit a bump it jars it loose just enough but goes back to making a contact.
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 12-04-2012, 08:49 PM   #5
UnbridledCarnage
Rhinoliner!!!
UnbridledCarnage's Avatar
Fan#: 66551
What I Drive: 03 Rhinoliner'd ZX3 AdvanceTrac
Points 16,266, Level 81
Points: 16,266, Level: 81 Points: 16,266, Level: 81 Points: 16,266, Level: 81
Level Up 84% Completed
FF Reputation: 9 UnbridledCarnage Good Standing Member
ive had this happen with my car. in the pass floorboard is the fuel cut off switch, check and make sure its fully plugged in. and check out FocusXtreme, we are based in louisville! Welcome to FF
If your local to the 502, 270, 812, 606, 859 area, check out FocusXtreme, the Ohio Valley chapter of FF. Monthly meets and kickass people! Join and POST UP!!!
UnbridledCarnage is offline
Old 12-05-2012, 01:18 PM   #6
Ill tempered Ian
Fan#: 57017
Here are my findings so far:
Wiring looks good at a glance (haven't dove that deep yet)
Located inertia cutoff and inspected press button to be sure
Went for a test drive troubleshooting most simple first
Hit a bump, off she went, at this point it would not start immediately and the following occurred.
Powertrain indicator lit up and lines on odometer
I am now getting dtc D262
WTF? Haha.
Old 12-05-2012, 05:40 PM   #7
Ill tempered Ian
Fan#: 57017
The culprit was a mere faulty relay, replaced almost all the relays not long ago, turns out one was a dud...
I guess I was just over thinking things.
Old 12-05-2012, 06:30 PM   #8
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 53%
Yay for easy fixes!
Moderator for
Technical Chat
