Who's replaced the head and not piston(s)?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-04-2012, 12:55 PM   #1
jscot
Fan#: 106744
What I Drive: 2001 Gold SE
FF Reputation: 1 jscot Good Standing Member
Going to put myself out for some bashing here! Just wondering who's willing to admit that they cleaned up a piston after a dropped valve seat and put a fixed head on, and the aftermath! Any burned out pistons?
I just did on my 2001 and it's running great. I went back and forth for awhile but needed to get this thing back on the road so just cleaned up the damaged piston (no noticeable damage to cylinders) and put a new head on.
I know many who have been through this have at least thought about it.
Pulling the head was pretty easy, so I figured, why not? Total rebuild was a whole 'nother level and just didn't make sense for this car.
I did replace timing belt and tensioner, new gaskets and plugs of course.
I think it'll be fine, I'm expecting another 100,000km.
Lots of info on head removal already on the site, so I won't go over my experience, but feel free to ask any questions.
I was toying with the idea of a used head, but the 2 Foci at the wreckers had both been scrapped because of the heads! Don't know why anyone would scrap an otherwise good car over this issue. Not that hard of a (half-assed) fix!
Let the bashing begin.
jscot is offline
Old 12-04-2012, 03:08 PM   #2
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
What I Drive: 2006 silver zx4 ses
Points 4,176, Level 41
Points: 4,176, Level: 41 Points: 4,176, Level: 41 Points: 4,176, Level: 41
Level Up 13% Completed
FF Reputation: 3 sam fisher Good Standing Member
at least its running lol. imo u gotta do wut u gotta do to make things work .
Sent from my N860 using FF Mobile
sam fisher is offline
Old 12-07-2012, 04:33 AM   #3
amc49
Fan#: 96610
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
Forum Activity 3%
Piston won't burn out, it breaks. The pistons are cast and extremely brittle under the right conditions. One of those conditions would be if impact was done on outer edge of piston up to 1/4" in, cracks there often let big pieces of the top piston ring land come loose later at any time depending on how cracked. You could be driving a time bomb but no way of knowing when it could happen. Could last forever, could break tomorrow, I've seen many cast pistons do it.
Depending on where piston was in stroke it could have yielded skirt to crack or maybe even break off a tang too, but you can't see that from the top. You could easily have a broken ring in there too.
You're the one that looked at it, your skillset now determines the outcome. I've done that too and on some the damage was only cosmetic and harmless, others no way. When person insisted on running it, it broke in a week.
You're in the hands of the SPI god now.
amc49 is offline
Old 12-07-2012, 06:20 PM   #4
fakitol
Fan#: 63209
What I Drive: 01 zx3 mtx,04 svt,01 zx3 atx, 02svt
Points 725, Level 14
Points: 725, Level: 14 Points: 725, Level: 14 Points: 725, Level: 14
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 1 fakitol Good Standing Member
Buy-Sell-Trade Rating: (11)
Did u clean the intake manifold and the dual stage runners?
fakitol is offline
Old 02-10-2013, 06:00 PM   #5
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
When you drop a valve seat the chunks get caught between the piston and head. It does a good amount of damage to both but the outer edge of the piston gets beat up pretty good. Enough to compress the lands and pinch the top ring so it no longer floats. A ring that doesn't float will probably wear out quicker than it should.
As someone else pointed out - did you clean out the broken valve seat parts from the intake/exhaust and EGR?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 02-10-2013, 09:15 PM   #6
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
I would not chance it, I have done 2 SPI rebuilds and put new pistons in one and used in the other.
I do have good piston/rod assemblies if anyone is interested, just PM me
Donnyd21 is offline
Old 02-10-2013, 10:12 PM   #7
amc49
Fan#: 96610
Forum Activity 3%
That is a cast piston, if the ring land has pinched then the cast has been yielded enough to VERY possible let sections of piston come loose next to do same thing again. Piston castings are very brittle, they take a lot of punishment but not that type. You can take one and easily crack pieces off by simply striking it with a hammer.
amc49 is offline
Old 02-19-2013, 01:32 PM   #8
jscot
Fan#: 106744
Thanks guys for the input. I did clean out the intake and smoothed out the piston crown. Running strong after a few months. I'll keep you posted!
Have had an issue with sucking air around the intake manifold when hot, but I'll post a new thread on that.
jscot is offline
