Cooling fan resistor , will my fan still work ? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-04-2012, 10:47 AM   #1
Fattie
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
Buy-Sell-Trade Rating: (6)
http://www.1aauto.com/1A/RadiatorFan...Fcyf4AodCHMAvA
this part on my fan rotted away to nothing , will my fan still work without it ?
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 12-04-2012, 10:59 AM   #2
Fattie
Fan#: 46016
i think this resistor is only for cars with ac , i have removed the ac from the car. hope that helps
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 12-04-2012, 11:37 PM   #3
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
that's a common issue on this forum; surprised you haven't seen it.
It's the low-speed half of the Focus's 2-stage cooling fan. Removing it reduces your cooling system to a one-speed fan that kicks on with the A/C or when the engine is on a trajectory to overheating. Of course, if your old resistor was already rotted away (open-circuit), then the fan won't even realize that you removed it.
If you haven't noticed this already, then you will start seeing the temp gauge creep over to the 2 o'clock position when you're sitting in traffic, at which point the 2nd-stage fan will kick on and the needle will creep back to 12 o'clock.
The added heat stress over the life of the vehicle certainly won't make the engine any younger, but from what I gather, many (most??) old Foci are on the road and completely unaware that their resistor died ages ago. (me)
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 12-05-2012, 12:54 AM   #4
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
Points 15,567, Level 80
Points: 15,567, Level: 80 Points: 15,567, Level: 80 Points: 15,567, Level: 80
Level Up 44% Completed
FF Reputation: 20 xxMichaelAnthony Great Standing Member
No fans will come on without the resistor. Mine has been bad for months. No fans! But, if you turn the AC on the big fan will come on for a little bit a couple times a minute.
http://effyeahfordcars.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 12-05-2012, 01:28 AM   #5
my_beautious_ZX3
Fan#: 32386
^sounds like there's more wrong with your cooling/electrical system than just a bad resistor.
Old 12-05-2012, 03:46 AM   #6
xxMichaelAnthony
Fan#: 58459
Electrical problem on the resistor side of the circuit. Both fans still come on during KOEO OBD test so its nothing in the fan circuit.
[HOONIGAN]
iTroll
Old 12-06-2012, 12:13 AM   #7
amc49
Fan#: 96610
Points 3,387, Level 36
Points: 3,387, Level: 36 Points: 3,387, Level: 36 Points: 3,387, Level: 36
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
The resistor controls low speed on both fans. High fans come on bypassing resistor at 240+ degrees or around 250+ psi highside on a/c.
Car will run with high fan only but it's a backup, you'll toast engine if that fails, the double fan speed setup is an automatically backed up system unless you insist on running it half failed. Head gasket jobs are always cheaper than resistors right?
When my resistor failed I rebuilt it and connector for like $7-$8 worth of parts. The resistor coil itself does not go bad, only the connections.
amc49 is online now
Old 12-07-2012, 12:31 AM   #8
Fattie
Fan#: 46016
mine was solid rust , i poke it with my finger and it just fell apart. im going to get a new one , and i didnt even bother to put the fan back in , its been around 30 degrees or lower here latley and the temp gauge stays right below half , and i keep the heat cranked. I will be buying a new one in a few days. thanks for the help
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 12-07-2012, 01:26 AM   #9
Top-Ace
Fan#: 61807
What I Drive: 2002, Silver Frost, ZTS
FF Reputation: 1 Top-Ace Good Standing Member
Dorman actually makes a kit for this problem (#902-219). Must be common enough that they decided to make a nice solution. Way cheaper then going the dealer route.
http://www.napaonline.com/Catalog/Ca...010_0388666574
Top-Ace is offline
Old 12-07-2012, 02:40 AM   #10
amc49
Fan#: 96610
Forum Activity 54%
Look how big the rest of the fan system connectors are as compared to the resistor connection, the resistor connector is smaller, and right at a heated point from resistor itself. Gotta wonder how much that engineer's college education cost......
No wonder Fords catch on fire so much, just saw another news story on it again couple of days ago.
amc49 is online now
