| Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more. Sponsored By:
#1 | ||||
svt brakes
any body know what letter in the vin is for svt rear brakes im trying too find rear calipers for a kit ?also do i need a svt master cyclinder if i switch from drums to svt rear disc brakes or is the proportioning on the zetec good for rear disc and front discs too?
Remove Advertisements |
Fan#: 1
#2 | ||||
Any '05-'07 ST or earlier focus w/ advance trac wil work, as the svt's use the same calipers. Use the same master cylinder you have.
Interduce Mr. Torsen to the mix |
#3 | ||||
thats what i was thinking........do i need too get the nuckels for the front swap too or just spindels hubs calipers and brackets?
#4 | ||||
For the front= use '05 spindles only & you'd need '05+ ball joints. The ball joints use a bigger stud for the bigger taperd diameter of the '05 spindle. Then you can use svt calipers & rotors. Get a set of ss brake lines.
#6 | ||||
Yeah, SVT knuckles will work great. Can you get them?
#7 | ||||
00-04 Focus will require the SVT knuckles for installation.
2011 SES 5spd #006 >> SR #213 Join the cause! 3 Door Fords for America! facebook.com/3DRS4US The internet is for finding an answer, not for finding ways to ask a question. |
#9 | ||||
You can also use '05 only spindles w/ '05+ ball joints. '05 spindles use the earlier smaller diameter struts & use the new for '05 bigger ball joints. The caliper mount spacing is svt size= hence you can bolt on svt rotors & calipers or any BBK.
| Thread Tools | |
| Display Modes | |
