Transmission Issues - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-03-2012, 11:58 AM   #1
ghozan1294
Fan#: 106676
What I Drive: 2001 Focus Yellow S.E. 2.0 Zetec
FF Reputation: 1 ghozan1294 Good Standing Member
Transmission Issues
So, I was driving on the highway going about 70 on cruise control, and suddenly the car revs itself and the yellow light that looks like a star with exclamation point inside went on. After about 3-5 seconds it turned off and the car arn perfectly again. I checked the trans fluid, it is brown. Should I do a pan drop and change the filter, or should I leave it? What else could be the cause of that light that went on. I've searched over google and people are saying its transmission issue. Any ideas? Thank you.
ghozan1294 is offline
Old 12-03-2012, 12:48 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Light brown may be a sign of coolant contamination,,, that may point to a problem in the radiator, a break that is allowing coolant to leak into the trans fluid.
Hopefully not though.
And yes, dropping the pan, changing the filter and fluid would be a good idea.
The light is for trans over temp. If the fluid is old/dirty it can't deal with heat as new would.
121,000 members and still no sponsored racing.
iminhell is offline
Old 12-03-2012, 01:57 PM   #3
ghozan1294
Fan#: 106676
thank you very much for your reply. As you open the hood there is a tube that coolant goes through it is right on top of the radiator. That has a coolant leak on one side and I put some putty on but it didn't help. Its leaking but very very slowly. What you are thinking is exactly what I am thinking. That since I was going on the highway for about 40 miles at 70 constantly the oil overheated, because I was driving around the city and nothing happend just on the highway. I will drop the pan tomorrow and change the filter and gasket and take it on a highway run again and see if it still does the same thing and I will let you know.
