Winter Fuel Econcomy - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-03-2012, 02:06 AM   #1
GoShockers
Fan#: 95869
What I Drive: 2012 Ford Focus SE Sport 6-Speed PS
FF Reputation: 2 GoShockers Good Standing Member
I noticed my average fuel economy dropped around 2 MPG's soon after November. I only fill up with non-ethanol fuel and was wondering if non-ethanol stations use a less efficient "winter blend" similar to normal, ethanol stations.
Also, how much of an impact on fuel mileage does cold air cause? Let's take away the fuel aspect and perhaps even the warm-up period. Does the colder, denser, "heavier" air cause enough problems aerodynamically to make a difference?
GoShockers is offline
Old 12-03-2012, 06:54 AM   #2
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
FF Reputation: 13 BetaDnB Great Standing Member
Colder air is more dense (as you stated) which requires more fuel for proper ignition. It also makes it more difficult for the car to cut through the air (aerodynamics). 2 mpg isn't bad of a drop. I lose about 5 mpg in winter also only using ethanol free.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 12-03-2012, 08:09 AM   #3
skiboarder119
Fan#: 98455
What I Drive: 2012 black TI 5spd
Points 373, Level 7
Points: 373, Level: 7 Points: 373, Level: 7 Points: 373, Level: 7
Level Up 46% Completed
FF Reputation: 1 skiboarder119 Good Standing Member
Whats said above is true, although with more dense air and more fuel to me would just mean that much more horsepower, so I always figured it was negligible (just my own deduction, I have no facts on that). Coming from a gearbox design background the thing that always gave us the most trouble was any type of bearing or coupled joint. In lower temperatures, they just never seem to warm up enough to have the same efficiency. I've always assumed wheel bearings and CV joints accounted for most of our winter losses.
skiboarder119 is offline
Old 12-03-2012, 08:39 AM   #4
JayDeZ
Fan#: 97919
What I Drive: 2014 Honda Accord Sport 6-sp manual
Points 1,581, Level 22
Points: 1,581, Level: 22 Points: 1,581, Level: 22 Points: 1,581, Level: 22
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
FF Reputation: 3 JayDeZ Good Standing Member
Here in CT they change the gas blend in November. The winter blend is less expensive (or so they say) than the summer bled, but it drops gas mileage by about 2-3 MPG. I went from 33 MPG average over the summer to 29-30 MPG now.
Check around to see if your state changes the gas blend for winter. That might be the problem.
Jay
JayDeZ is offline
Old 12-03-2012, 09:23 AM   #5
SydneyRoo
SydneyRoo's Avatar
Fan#: 86671
What I Drive: 2012 Titanium Blue Candy
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 2 SydneyRoo Good Standing Member
My fuel economy has gone up by 2 mpg ever since I took my summer 18s off and put my winter 16s on. Man those 18s kill my fuel mileage..
2012 Blue Candy Titanium!
Former 03 Vibe, 96 Sunfire, 90 Prelude, 87 Civic
SydneyRoo is offline
Old 12-03-2012, 09:41 AM   #6
ransil
Fan#: 86614
What I Drive: 2012 Blue TI when it gets here..
Points 38, Level 1
Points: 38, Level: 1 Points: 38, Level: 1 Points: 38, Level: 1
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 ransil Good Standing Member
Are the tire rotations per mile the same for both sets of tires? Could be a calculation issue.
Sent from my Galaxy Nexus using FF Mobile
ransil is offline
Old 12-03-2012, 09:57 AM   #7
SydneyRoo
SydneyRoo's Avatar
Fan#: 86671
I've checked it out, the rotations ratio is negligibly close. Factory 18s are 235/45/18 and my winters are 205/55/16
Old 12-03-2012, 10:18 AM   #8
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
Points 173, Level 3
Points: 173, Level: 3 Points: 173, Level: 3 Points: 173, Level: 3
FF Reputation: 1 jdetzel Good Standing Member
According to here:
http://1010tires.com/tiresizecalcula...?action=submit
There would be about a 6% increase with the smaller tires.
In other words if you traveled 100 miles your odometer would actually show 106 miles.
It actually says 5.833%, which @ 30mpg would show as a 1.7mpg increase.
That is just what that site says, I do not actually know how to do any of the tire size calculations.
jdetzel is offline
Old 12-03-2012, 12:05 PM   #9
PDQEagle
Fan#: 9356
What I Drive: 03 Focus ZX3
FF Reputation: 11 PDQEagle Great Standing Member
I've gone thru 7 winters in massachusetts, and drive the same commute each day, with little weekend travel. My commute is not highway, but I can go 45-50 most of the time, with few stops and slowdowns. Summer I get a consistant 30-31 mpg, winter consistant 27-28, like clockwork.
The cold effects in several ways. All fluids (oil and grease) are thicker so offer resistance. Tire pressure goes down, if you haven't checked it. My previous Eclipse with awd, in summer backing up out of the drive, clutch in, it would coast. In winter, definitely stop coasting much quicker.
Gas gets vaporized poorer so less efficient burn (regardless of electronics), engine warm up even if you start off rightaway, traffic slowdowns.
The change from summer to winter gas is mostly to ease vaporization, and I can't believe the little power difference would make much difference
PDQEagle is offline
Old 12-03-2012, 12:58 PM   #10
gkirk
Fan#: 91903
What I Drive: 2012 C.Red Focus SE Sport Package
Points 391, Level 7
Points: 391, Level: 7 Points: 391, Level: 7 Points: 391, Level: 7
Level Up 82% Completed
FF Reputation: 3 gkirk Good Standing Member
Don't forget that tire pressure will drop a bit with temperature too. Not sure exactly how much it will drop, but I found a reference that it is about 1psi / 10 degrees F.
So if you inflated them at 70F, they will be 3-4 psi lower at 32F. That can cause a noticeable drop to gas mileage.
gkirk is offline
