2005 2.0 Engine/Tranny Compatibilty - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 12-03-2012, 12:37 AM   #1
rev9k
Fan#: 106904
What I Drive: 2005 Red Focus ZX4
FF Reputation: 1 rev9k Good Standing Member
Hey guys. Quick question.
I have a working 2.0 engine and auto tranny from a 2005 Focus ZX4.
I am wondering what years this combo will drop into without much hassle?
Im thinking 2000-2007. Is that correct? Or will this work in the newer 2007-2011 body as well?
Thanks.
rev9k is offline
Old 12-03-2012, 06:38 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
The problem is not going to be the engine so much as the computers. Hopefully you get a car with a bad motor, and then you've not no problem swapping. That engine will fit in 05-11 Focis without many issues- provided the car you find has an engine in it. If it doesn't, then you might be missing some parts. 05-07 have the same air cleaner, but the 08+ is different- the MAF is different, then air filter itself is different- yadda yadda yadda.
Your best bet is to find an 05- not so much because that's the engine and trans you have, but because those will be older and you'll probably have better luck finding one with a blown engine.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 12-03-2012, 10:22 AM   #3
rev9k
Fan#: 106904
Thanks for the reply. I'm not too concerned with having to search for a full vehicle. What I am confused on is the mounts.
I really like the 08-11 styling a lot more and I would be willing to shell out a little more for a newer chassis. I'm just worried that I will have to fab too much to drop it in. I should have been more clear about what I have. The engine and tranny are currently in a running vehicle that I'm going to pull everything put of so I would have everything I need? Will the PCM swap right into the newer chassis? What about the engine side wiring harness?
Thanks so much for the info.
rev9k is offline
Old 12-04-2012, 11:09 AM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,940, Level 74
Points: 12,940, Level: 74 Points: 12,940, Level: 74 Points: 12,940, Level: 74
Level Up 23% Completed
Forum Activity 99%
The motor & trans will fit w/ no issues. Its the pcm, I'd figure out if the '05 pcm can plug into the '08+ cars. Or you can use the oem pcm on the '05 motor w/ a tune. The '08+ cars use a cam senser on the intake, not sure what it does. Maybe someone else can chime in on that feature.
felixthecat is offline
