PAC SOEM-4 LOC with remote turn on - Focus Fanatics
Go Back   Focus Fanatics > Model Specific Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 12-02-2012, 08:21 PM   #1
Besbro
Besbro's Avatar
Fan#: 102785
What I Drive: 2012, black SE Sport
FF Reputation: 1 Besbro Good Standing Member
Hello, I recently installed a 2 channel amp and components in my 2012 Focus hatch with the 6 speaker factory system. I used the PAC SOEM-4 LOC with the remote turn on. Everything works and sounds great except when I walk out to my car and open a door (the car is not running, keys are not in the ignition) the amp turns on for about 30 seconds and then turns off again. No music plays but it just powers on. I wired up the 12v power off the loc to my amp 12v, I wired the local ground to my amp ground post(on the amp itself) and fed the remote line off the loc to the remote turn on post on the amp. Any ideas???
Thanks!
Besbro is offline
Old 12-02-2012, 09:30 PM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 SCrew 5.0
FF Reputation: 9 Kipp Good Standing Member
alot of those LOC's that create their own turn-on tend to function weird. I've never used one that has actually provided a reliable turn-on output. I would suggest getting that from somewhere else in the car.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 03-11-2013, 09:34 PM   #3
Pilot
Fan#: 106774
What I Drive: 2013 Ruby Red Ford Focus SE
FF Reputation: 1 Pilot Good Standing Member
Thanks!
Hey guys and girls. I have the same problem with my 2013 fofo BUT I do not have a loc at all get this I open my doors and boom my brand new Pioneer GM-D8604 powers on with no sound just the obligitory speaker thump even with the head unit turned off what gives I called crutchfield and they sugested I install a PAC soem4 to fix the prob.
I used the speaker level inputs and installed RCA plugs for the amp side thing has one heck of a speaker thump when I start the car even with the head unit off bth I kept the stock head standard 6 speaker non sony unit.
Pilot is offline
Old 03-11-2013, 09:38 PM   #4
Kipp
Kipp's Avatar
Fan#: 31300
what is the remote turn on lead connected to? you're issue is that for whatever reason the amp is already on when it shouldn't be.
Midwest Crew #22
Kipp is offline
Old 03-23-2013, 10:23 PM   #5
Pilot
Fan#: 106774
Hello Hello again, My pioneer amp is a new gen amp with auto turn on via RCA input.The silly trigger is hooked up to a switched 12 volt but according to crutchfield the trigger on this perticular amp is only needed if using more than one amp. It seems that this amp is not compatible with the 2013 fofo head unit as their is really no way to turn it off, the doors.hood and hatch sind a signal to the info system when they are opened and from their to the can data network acc, system on this unit. Personally this would have been a good thing to disclose at purchase of the amp, heck for that reason even at purchase of the fofo.
Pilot is offline
Old 03-24-2013, 08:20 AM   #6
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
Get an add-a-circuit fuse tap and pull power from your fuse panel using a circiut that only has power when ign is on. Run that to your amp turn on. This will solve your problem.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
