Help plz - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-02-2012, 08:37 PM   #1
8.5Racing
8.5Racing's Avatar
Fan#: 106907
What I Drive: 1987 brown mustang
FF Reputation: 1 8.5Racing Good Standing Member
Help plz
I got a 2000 focus dohc i goto replace timin belt i use flat bar on camshafts and i dont have the pin that goes in back block so i get #1 up to tdc lettin the piston push screw driver up an the keyway on crank is straight up put it together check make sure nothin is hittin by turnin it over by hand goto start it and car runs but have to give it gas it will not idle.....what did i do wrong?
8.5Racing is offline
Old 12-03-2012, 12:22 AM   #2
8.5Racing
8.5Racing's Avatar
Fan#: 106907
Anyone???????
Old 12-03-2012, 01:21 AM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,414, Level 86
Points: 18,414, Level: 86 Points: 18,414, Level: 86 Points: 18,414, Level: 86
Level Up 13% Completed
Forum Activity 6%
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Cam timing is off.
Don't use a screwdriver.
Use air pressure to force #2/4 to BDC. You'll have to move the cams to close the valves but it works better than anything else I've found to find true TDC #1.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 12-03-2012, 06:31 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,546, Level 98
Points: 27,546, Level: 98 Points: 27,546, Level: 98 Points: 27,546, Level: 98
Level Up 20% Completed
Forum Activity 13%
Well, for one, you're not in the right section- I can help with that. Moved to General Technical Chat.
So, the car starts, then dies? Did you disconnect the IAC at all? Have you removed the IAC to clean it and make sure it's plunger can move- it's not caked up with black oily crud?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 12-03-2012, 02:25 PM   #5
8.5Racing
8.5Racing's Avatar
Fan#: 106907
I dont see it bein iac because it was jus runnin fine till i did the timin belt
Old 12-03-2012, 02:28 PM   #6
8.5Racing
8.5Racing's Avatar
Fan#: 106907
Originally Posted by iminhell View Post
Cam timing is off.
So i jus put the air hose to #2 and #4 and it will make #1 tdc?
Old 12-03-2012, 02:45 PM   #7
8.5Racing
8.5Racing's Avatar
Fan#: 106907
Btw thanx for yas help
1.20 60ft 5.77 @ 120 1/8th on 26 8.5 with no kind of controllers
Old 12-03-2012, 03:04 PM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 6%
So long as the valves are shut, yes.
A 4cylinder is 180* opposed. If 1/3 is at TDC then 2/4 have to be at BDC.
There is no box.
iminhell is offline
Old 12-03-2012, 04:22 PM   #9
8.5Racing
8.5Racing's Avatar
Fan#: 106907
Ok im gonna take it apart again see where i went wrong ill let you know thanx for help
