More Tire Width - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 12-02-2012, 08:06 PM   #1
DerbyCityGinger
DerbyCityGinger's Avatar
Fan#: 106672
What I Drive: 2005 Sonic Blue ZX5
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 1 DerbyCityGinger Good Standing Member
More Tire Width
I read a thread about tire sizes and upgrading rim size but my question has to do more with width. Generally speaking, the more rubber on the ground, the better performance, right? I was wondering what the best size for a ZX5 was. Stock are 195/60R15, but is it possible to put 205/50R15 size tires on it?
Also, if I were to put 16 inch rims on it, would 215/45R16 work or is that too wide? I'm not really planning on it, but it would be helpful to know.
DerbyCityGinger is offline
Old 12-02-2012, 08:26 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,014, Level 71
Points: 12,014, Level: 71 Points: 12,014, Level: 71 Points: 12,014, Level: 71
Level Up 91% Completed
Forum Activity 99%
FF Reputation: 65 felixthecat Excellent Standing Member
Yes you can run 205/50R15s on a 6'' wheel. Your best combo is 16'' wheels w/ a 205/50R16's. You should be able to pick up a set of 16'' alloy oem wheels cheap. For 17's a popular combo is using the SVT wheels=7x17's w/ a oem size 215/45R17.
felixthecat is online now
Old 12-02-2012, 09:41 PM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
205/55-15 would be a little closer to the overall diameter you should be looking for. Try to shoot for an overall tire diameter of 24 to 24.5 inches. This will keep your odo and speedo reasonably accurate. The 205/50-15 size due to its smaller diameter, will result in slightly better acceleration as it modifies the final gear ratios. That size will also result in higher RPM's at higher speeds and reduced fuel economy.
Geezer is offline
Old 12-02-2012, 09:57 PM   #4
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 2,997, Level 33
Points: 2,997, Level: 33 Points: 2,997, Level: 33 Points: 2,997, Level: 33
Level Up 65% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
A 195 from a good brand will perform better than a 205 from a cheap brand.
So don't decrease the quality of your tire so you can afford to go wider...........
Ed
emsvitil is offline
Old 12-03-2012, 01:56 PM   #5
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,581, Level 37
Points: 3,581, Level: 37 Points: 3,581, Level: 37 Points: 3,581, Level: 37
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 23 wrc_fan Great Standing Member
Generally, yes, if both tires are of the same rubber compound and construction.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 12-03-2012, 02:30 PM   #6
sailor
Crankshaft
sailor's Avatar
Fan#: 57268
Points 11,816, Level 71
Points: 11,816, Level: 71 Points: 11,816, Level: 71 Points: 11,816, Level: 71
Level Up 42% Completed
Forum Activity 99%
NOT to "Pick Nits" here, but at the same inflation pressure ANY size tire will have the SAME "rubber on the ground".
Changing tire width &/or profile changes the SHAPE of that "footprint" leading to advantages or disadvantages in different circumstances.
Wider tires give a shorter, wider footprint - an advantage at high speeds because of less "contact time" heating up the tread - a disadvantage for Snow Tires because the added width causes increased flotation (wider also needs larger rain groves to counteract hydroplaning for the same reason)
Lower profile, commonly used to keep the same overall diameter when adding width, gives quicker steering response due to the reduced sidewall height vs. width. This gives the "Sportier" feel usually attributed to wider tires.
Wider rims to match the wider tires add greatly to the quicker steering response from lessened sidewall deflection. Extreme version is to use wheels that are wider than the tire's tread (stretched). Quite common in racing applications, and a dramatic difference even if the wheel is only slightly wider than the tread width (for example a 5" tread width on a 6" wide rim).
Plenty more "fine points" to the subject, but that gives the general idea...
sailor is offline
