Duratec 2.0L owners.. do you experience long cranking/need for multiple start attempts? - Page 2 - Focus Fanatics
View Poll Results: Do you experience starting difficulty with your Duratec 2.0L Focus?
All the time 6 23.08%
sometimes 7 26.92%
seldom 3 11.54%
never 10 38.46%
Voters: 26. You may not vote on this poll
Old 12-03-2012, 12:21 PM   #11
rev9k
Fan#: 106904
What I Drive: 2005 Red Focus ZX4
FF Reputation: 1 rev9k Good Standing Member
2005 2.0L. 133K. No start issues for me.
But.... If it is air related, I have never changed the "Magic Forever" air filter so maybe Im plugged up a little and its helping the hard start?
rev9k is offline
Old 12-04-2012, 09:27 PM   #12
xRESSLERxZX3x
xRESSLERxZX3x's Avatar
Fan#: 100517
What I Drive: 98 zx2 sport
FF Reputation: 1 xRESSLERxZX3x Good Standing Member
I just flip the key to run then let it sit till its done dinging and it starts right up every time
Focus Revolution
Rally Revolution #20
Team Duratec #37
[HOONIGAN]
I fear no evil, for the shadow is mine and so is the valley
xRESSLERxZX3x is offline
Old 12-04-2012, 09:53 PM   #13
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
What I Drive: 2006 silver zx4 ses
FF Reputation: 3 sam fisher Good Standing Member
wierd lol mine does this bad but its an 06
Sent from my N860 using FF Mobile
sam fisher is offline
Old 12-05-2012, 10:57 AM   #14
spayne13
Fan#: 81196
What I Drive: Silver 2005 ZX4 ST
FF Reputation: 1 spayne13 Good Standing Member
TSB for Hard Starting
There is a TSB out for the 2005 model year 2.0L/2.3L and MTX-75 for hard starting. The TSB is 05-9-16. I bought mine used and the previous owner did not have it done, and I do have hard starting, especially if the ambient temperature is between about 30 - 65 degrees. I believe mine gets too much fuel when starting issues occur. If it takes longer than one second to start, I keep cranking and begin depressing the accelerator pedal. The car will then start, usually with a little puff of black smoke (indicating a rich start).
spayne13 is offline
Old 06-08-2013, 03:27 AM   #15
LensDriven
LensDriven's Avatar
Fan#: 111184
What I Drive: 2006 Blk ZX4 SES, 2009 Blu Coupe SE
FF Reputation: 1 LensDriven Good Standing Member
Our 06 is like that- without fail, 2 longish crank attempts if its been sitting a bit. Always on the second one though. Doesn't matter what suggested tricks we try, it's always 2. Just learned to live with it. Can't seem to fix it with all the clean this and that tips I've heard.
Edit: it's got 69000 miles
LensDriven is offline
Old 07-13-2013, 08:17 PM   #16
#1fordfan
Fan#: 83143
What I Drive: 2005 white se zx4
FF Reputation: 3 #1fordfan Good Standing Member
this works for my car also. I have noticed that keeping filters and plugs changed helps a little also.
#1fordfan is offline
Old 07-14-2013, 08:34 AM   #17
Yankabilly
Fan#: 116640
What I Drive: 2005,2007,zx5 2008 zx4 all 2.0
FF Reputation: 1 Yankabilly Good Standing Member
Clean the throttle body and the air flow sensor, started using sea foam and the 108 octane ( made for fuel injectors ) took care of problem until she drove thru water 😡
Use the 108 once a month and the sea foam every other fill up
Also don't let tank stay below half of tank for long, the gas keeps the fuel pump cool and last longer.
When was the last time fuel fillter was changed?
Also I change spark plugs every 75,000 miles and use the anti sees
Even on my new one I took them out and put it on them, the motor maker ( not ford ) does not put enough if any at all
Yankabilly is offline
Old 11-18-2013, 05:38 PM   #18
focusrenton
Fan#: 117393
What I Drive: 2005 Light Tundra ZX4
FF Reputation: 1 focusrenton Good Standing Member
Smile
So do you happen to know what the TSB says? I have just started experiencing this problem on my 05 ZX4 and I cannot stand it. If anyone knows what can be done please let me know
focusrenton is offline
Old 11-18-2013, 06:40 PM   #19
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 270 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Your problem might not be this problem. The general problem was that there was too much air allowed in the engine for startup. This might still be your problem, but might be caused by something else.
I suggest you start your own thread instead of latching on to this old one which was started in 2012.
I can tell you what I do with my car- I bump the engine, if it doesn't start immediately at the first little turn of the motor, I turn it back off. The second start fires right up every time it does it. I've gotten so used to this that I don't even think about it any more, so I can't tell you when the last time was that it happened.
You might have some sort of vacuum leak, dirty MAF, or air intake leak if you didn't have the hard start problem previously and then now you do.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-21-2013, 08:54 AM   #20
focusrenton
Fan#: 117393
thank you whynotthinkwhynot. I am new to this so I didn't want to make a new thread for something that had already been posted. I will clean or replace the MAF and see if that helps my issue.
