Please, I'm begging you all... - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-01-2012, 02:49 AM   #11
Andrews-bad-SE
Fan#: 100389
What I Drive: 2003 Arizona Beige SE 4dr Zetec/ATX
FF Reputation: 3 Andrews-bad-SE Good Standing Member
Originally Posted by mikebontoft View Post
If I am not mistaken, NTK is not a recommend sensor for these... however I doubt that is the problem. 50% doubt anyway. bad new parts are of no surprise to me. verify that you have no exposed wires though.
I haven't posted in threads previous because it didn't make any sense. now that we have more information, I think you'll get some more help. Insulting other members won't get you far either though.
I heard that NTK's are recommended though? funny you should say that though, I bought 2 of the same sensor. One from rockauto.com, and the problem persisted. So I thought the same thing you did, and got another... still nowhere lol. I'm going to check my wiring, and make sure no water's in the connector or anything. Thanks for your input!
About insulting people. Not my intention. Sorry to anyone offended... I just don't like undue rantings. Not a fan. iminhell's a smart guy, I have a lot of respect for him. There are a lot of things he's helped me with, directly or indirectly just reading through the forums. I'm also not a fan of internet bickering, so I'm squashing it before it goes insane.
Andrews-bad-SE is offline
Old 12-01-2012, 07:00 AM   #12
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
HA40 DTC P1131, P1151, P1132, P1152, P2195, P2196, P2197 AND P2198: UPSTREAM HO2S(S) NOT SWITCHING. DTCs P1130 AND P1150: FUEL SYSTEM NOT SWITCHING AT THE FUEL TRIM (RICH OR LEAN)
HO2S DTCs Reference list
HO2S-11 = DTCs P1131, P1132, P1130, P2195 and P2196
HO2S-21 = DTCs P1151, P1152, P1150, P2197 and P2198
Check intake air system for leaks, obstructions, damage and blockage.
Verify integrity of the PCV system.
Check for disconnected spark plug wires.
Check for vacuum leaks.
Are any of the above concerns present?
Yes No
REPAIR as necessary. GO to DC25 .
DC25:
DC25 DTC P0171, P0172, P0174, P0175, P1131, P1132, P1151, P1152, P1130, P1150, P2195, P2196, P2197, P2198 OR LEAN DRIVEABILITY CONCERNS: CHECK CONDITIONS RELATED TO MAF SENSOR
Note: Most weather service reports are a local barometric pressure that has been corrected to sea level. However, the BARO PID reports the actual barometric pressure for the altitude the vehicle is being diagnosed in. Local weather conditions (high or low pressure areas) will change the local barometric pressure by several inches of mercury [+/- 3 Hz. (+/- 1 in.Hg.)].
Note: The BARO PID values in Keep Alive Memory require updating at high throttle openings. If vehicle is driven down from higher altitudes for diagnosing, complete three or four heavy accelerations at greater than half-throttle to allow BARO PID to update. Make BARO PID comparisons to Barometric Pressure Reference Chart or hourly airport barometric pressure or altimeter reports, if available. The BARO PID must be within +/- 6 Hz. (+/- 2 in.Hg.) of the altitude value in Barometric Pressure Reference Chart (at the beginning of this pinpoint test).
Note: A MAF V PID value of less than 0.6 volt may indicate a misassembled air cleaner or a leak in the air inlet system.
Verify the MAF sensor is connected. If not, repair as necessary.
Key on, engine running.
Access the BARO, LONGFT1, LONGFT2 and MAF V PIDs on fully warmed-up engine.
Carry out the following diagnostic checks:
Check that the BARO PID is approximately the same as the barometric pressure reading for the location, day and altitude the vehicle is being diagnosed at.
Check that the MAF V PID at idle and neutral is not greater than 30% of the normal MAF V listed in Section 6 , Reference Values (or not greater than 1.3 volts).
Are the PID values within the expected ranges?
Yes No
For DTC P0171, P0172, P0174, P0175, P1131, P1132, P1151, P1152, P1130, P1150, P2195, P2196, P2197 or P2198 : Unable to duplicate or identify the fault at this time, GO to Z1 (or GO to HA42 for natural gas vehicles only). For driveability symptoms without DTCs : RETURN to Section 3 , Symptom Charts for further diagnosis. KEY OFF. GO to DC26 .
DC26:
DC26 CHECK TO ISOLATE MAF SENSOR FROM LEAN DRIVEABILITY OCCURRENCE
Note: Due to increasingly stringent emission/OBD II requirements, a fuel system DTC on some vehicles will be generated without a noticeable driveability concern with or without the MAF sensor disconnected. Under these conditions, if the BARO, LONGFT1, LONGFT2 and MAF V PID indicates a MAF sensor concern, replace the MAF sensor.
Disconnect the MAF sensor.
Drive the vehicle.
Is the lean driveability symptom (lack of power, spark knock/detonation, buck/jerk or hesitation/surge on acceleration) gone?
Yes No
REPLACE MAF sensor.
RESET the keep alive memory (KAM). REFER to Section 2, Resetting The Keep Alive Memory (KAM) .
VERIFY a symptom no longer exists. For DTC P0171, P0172, P0174, P0175, P1131, P1132, P1151, P1152, P1130, P1150, P2195, P2196, P2197 or P2198 : Unable to duplicate or identify the fault at this time, GO to Z1 (or GO to HA42 for natural gas vehicles only).
For lean driveability symptoms listed without DTCs : RETURN to Section 3 , Symptom Charts for further diagnosis.
Typical Diagnostic Reference Values
Sensors/Inputs PCM Pin/PID only Measured/PID Values Units Measured/PID
KOEO Hot Idle 30 MPH 55 MPH
FEPS 13 .5-.6 .5-.6 .5-.6 .5-.6 DCV
CKP (+) 21 0 400-425 900-1000 1150-1400 Hz
PSP V/PSP 31 .1/LOW VBAT/HIGH (I) .1/LOW .1/LOW DCV/ LOW-HIGH
O2S12 35 .1 (D) (D) (D) DCV
CHT V/CHT 38 .67 or 3.7/194 .67 or 3.7/194 .67 or 3.7/194 .67 or 3.7/194 DCV/DEG
IAT 39 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) DCV/DEG
FPM 40 3.5/100 3.5/100 3.5/100 3.5/100 DCV/%
ACCS 41 .1/OFF VBAT/ON (A) .1/OFF .1/OFF DCV/OFF-ON
PATSIN 53 (T) (T) (T) (T) (T)
KS 57 0 0 0 0 DCV
OSS 58 0 0 200-220/
430-450 360-827 Hz/RPM
GFS 59 0 130/30 130/27 130/23 Hz/%
O2S11 60 0 switching (C) switching (C) switching (C) DCV
FRPV/FRP 63 3/43 2.8/39 2.8/39 2.8/39 DCV/PSI
FTP V/FTP 62 2.6/0 2.6/0 2.6/0 2.6/0 DCV/IN-H20
CPP/PNP 64 5/OFF .1/ON (J) 5/OFF 5/OFF DCV/OFF-ON
DPFEGR 65 .25-1.30 .25-1.30 .25-4.65 .25-4.65 DCV
CID 85 0 5-7 11-15 16-21 Hz
ACP 86 VBAT/OPEN VBAT/OPEN VBAT/OPEN VBAT/OPEN DCV/OPEN-
CLOSED
MAF V 88 0 .6-.9 1-1.6 1.3-2.3 DCV
TP V 89 .53-1.27 .53-1.27 1-1.3 1.1-1.9 DCV
BPP 92 .1/OFF VBAT/ON (E) .1/OFF .1/OFF DCV/OFF-ON
ECT PID 160-200 160-200 160-200 160-200 DEG
EFTA PID 50-120 (K) 50-120 (K) 50-120 (K) 50-120 (K) DEG
FLI PID 50 50 50 50 %
LOAD PID (L) 10-20 20-31 25-52 %
MISF PID OFF OFF OFF OFF OFF-ON
OCTADJS PID NO RETARD NO RETARD NO RETARD NO RETARD NO RETARD/
RETARD
RPM PID 0 700-750 1630-1820 2100-2400 RPM
VSS PID 0 0 30 55 MPH
Actuators/ Outputs PCM Pin/PID only Measured/PID Values Units Measured/PID
MIL 2 .1/OFF VBAT/OFF VBAT/OFF VBAT/OFF DCV/OFF-ON
HFC 17 VBAT/OFF .1/ON (B) VBAT/OFF VBAT/OFF DCV/OFF-ON
INJ3 20 0 3.3-3.7 4.1-8 4.4-10.1 mS
PATSOUT 19 (T) (T) (T) (T) (T)
CDA 26 VBAT VBAT VBAT VBAT DCV
PATSTRT 27 (T) (T) (T) (T) (T)
VSO 28 0 0 65 125 Hz
PATSIL 42 (T) (T) (T) (T) (T)
EGRVR 47 VBAT/0 VBAT/0 (V) (V) DCV/%
CTO 48 0 25-38 48-59 72-85 Hz
CDB 52 VBAT VBAT VBAT VBAT DCV/%
FP 54 3.7/75 1.3-26 1.5/27 1.5/30 DCV/%
EVAPPDC 56 0 0-10/0-100 0-10/0-100 0-10/0-100 Hz/%
EVAPC V 67 0 0-10/0-100 0-10/0-100 0-10/0-100 DVC/OFF-ON
LFC 68 VBAT/OFF .1/ON (B) VBAT/OFF VBAT/OFF DCV/OFF-ON
WAC 69 VBAT/OFF .1/ON (A) VBAT/OFF VBAT/OFF DCV/OFF-ON
GENFDC 72 0 0 0 0 Hz/%
INJ1 70 0 3.3-3.7 4.1-8 4.4-10.1 mS
MFC 75 VBAT/OFF .1/ON (B) VBAT/OFF VBAT/OFF DCV/OFF-ON
IAC 83 VBAT/0 9-11/20-40 8-11.1/34-50 6-7.5/45-60 DCV/%
HTR11 93 .1/ON (P) .1/ON .1/ON .1/ON DCV/OFF-ON
INJ2 96 0 3.3-3.7 4.1-8 4.4-10.1 mS
INJ4 95 0 3.3-3.7 4.1-8 4.4-10.1 mS
HTR12 100 .2/ON (P) .2/ON .2/ON .2/ON DCV/OFF-ON
CHTIL PID OFF OFF OFF OFF OFF-ON
FUELPW1 PID (L) 3.3-3.7 4.1-8 4.4-10.1 mS
LONGFT1 PID (-)20-(+)20 (-)20-(+)20 (-)20-(+)20 (-)20-(+)20 %
SHRTFT1 PID (L) (-)10-(+)10 (-)10-(+)10 (-)10-(+)10 %
SPARKADV PID 0 15-33 28-35 25-35 DEG
Other PCM Pin/PID only Measured/PID Values Units Measured/PID
KAPWR 55 VBAT VBAT VBAT VBAT DCV
VPWR 71 VBAT VBAT VBAT VBAT DCV
VREF 90 5 5 5 5 DCV
No clue what capabilities your scan tool has. But you'll want to view live data. If you can't view live data, you're not going to get anywhere in any reasonable time.
My best guess's,
- O2 heater fuse is blown
- MAFS is in backwards
- FRPS is damaged
The STFT's should switch around a centerpoint of 1. This code means that centerpoint is either lower than 1 and LTFT's can not correct it; LTFT's can correct up to 25%, that is leaning the mix 25% ... which still isn't enough and this code is thrown.
When viewing live data you'll probably see STFT's in the range of 0.825 and stable. This means the car is running forced open loop because of something. LTFT's will probably read 1.25 or near, trying to remove fuel.
I'll bet the MAF_V is going to be all over the place if it's reading at all.
121,000 members and still no sponsored racing.
iminhell is offline
Old 12-01-2012, 07:05 AM   #13
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Dang iminhell went all technical lol
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 12-02-2012, 12:54 PM   #14
Andrews-bad-SE
Fan#: 100389
my scan tool cant do live data, but my buddys got a genesys that can do that. ill check that fuse... (i didnt even know there was one for that...). MAF is in correctly, and not leaking. No obvious vac. leaks, but thats not saying there isnt any at all. thanks a lot man!
Old 12-02-2012, 01:25 PM   #15
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
A vacuum leak will generally go lean. You're going rich. That indicates either an air metering issue (bad MAFS) or something in the fuel system (sticking injector, high pressure, leaking Fuel Rail Pressure Sensor).
Knowing that will help narrow down the list of possibles.
Things like this can be tough and that's why we needed more info.
I'm confident we can get this sorted out. Will just take a bit of time and good scan tool with live data. Don't want you replacing good parts.
Posted from NAPA.
iminhell is offline
Old 12-03-2012, 10:09 PM   #16
Andrews-bad-SE
Fan#: 100389
Alright here's an update... its also throwing "egr insufficient flow" and "system lean bank 1." I think i could have a vac leak, maybe the Egr gasket? is this a sound theory?
I know you just said it sounds like I'm running rich... Not knocking your input. Just updating my info
Old 12-04-2012, 12:49 AM   #17
Screachin93
Fan#: 95816
What I Drive: 2000 ZTS
Points 76, Level 1
Points: 76, Level: 1 Points: 76, Level: 1 Points: 76, Level: 1
Level Up 52% Completed
FF Reputation: 1 Screachin93 Good Standing Member
I know these cars have DPFE sensors now I had an explore that threw the same codes and that was the cause now I'm not saying that's the issue but its worth checking into
Screachin93 is offline
Old 12-04-2012, 01:16 AM   #18
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,177, Level 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Level Up 14% Completed
Forum Activity 3%
FF Reputation: 4 matmatician Good Standing Member
Iminhell's pretty good with this stuff, he helped me troubleshoot an o2 sensor that was causing me to burn rich.
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 12-04-2012, 02:24 AM   #19
Andrews-bad-SE
Fan#: 100389
The DPFE is the "egr pressure feedback" sensor, right? the one with two hoses and an electrical connector mounted with two screws to the firewall?
It's new... I thought the same thing. Also, I accidentally broke my old one while hooking up a new EGR tube. Woops!
Old 12-04-2012, 06:18 AM   #20
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
A drop of oil from the dipstick (use your fingers to wipe some on outside of the DPFE port) will make those tubes slide on much easier. I broke one on my wife's van. Fortunately, in 05 the DPFE was integrated into the EGR. I assume that plan worked, and I don't know of a DPFE on following Focis.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
