Please, I'm begging you all... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-30-2012, 11:19 PM   #1
Andrews-bad-SE
Fan#: 100389
What I Drive: 2003 Arizona Beige SE 4dr Zetec/ATX
FF Reputation: 3 Andrews-bad-SE Good Standing Member
In case you (the reader) are new, here's a back story so you don't have to see the other posts about this (and ):
I have a 2003 Zetec with a CAI.
Lately, it's been throwing a PO2195 code (Upstream O2 sensor stuck/biased lean, bank 1, sensor 1).
I've been searching high and low for answers, and nothing's working.
I even did some thinking, checked for vaccuum leaks. Nothing.
I don't know what to do, i'm at my wits end here.
I need someone with some experience to shoot me some advice!
Andrews-bad-SE is offline
Old 11-30-2012, 11:34 PM   #2
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,869, Level 25
Points: 1,869, Level: 25 Points: 1,869, Level: 25 Points: 1,869, Level: 25
Level Up 69% Completed
Forum Activity 3%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
P2195- Lack of H2OS-11 switch, Sensor indicates lean.
Description: A HUGO sensor indicating lean at the end of a test is trying to correct for an over rich condition. the test fails when the fuel control system no longer detects switching for a colibrated amount of time.
Possible causes:
ELECTRICAL
Short to VPWR in harness or HO2S sensor
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S sensor
Damaged PCM
FUEL SYSTEM
Excessive fuel pressure
Leaking fuel injectors
Leaking fuel regulator
Low fuel press or running out of fuel
Vapor recovery system
INDUCTION SYSTEM
Air leaks after MAF
Vacuum leaks
PCV system
Improper seated engine oil dipstick
EGR SYSTEM:
Leaking gasket
Stuck EGR valve
Leaking diaphrame or EVR
BASE ENGINE
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near HO2S sensor
Have you replaced the 02 sensor?
mainest is offline
Old 11-30-2012, 11:40 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,933, Level 87
Points: 18,933, Level: 87 Points: 18,933, Level: 87 Points: 18,933, Level: 87
Level Up 17% Completed
Forum Activity 11%
Buy-Sell-Trade Rating: (4)
You know, it's really damn hard to help when I have to read 15 back threads about the same thing. All of which have very little information to go on.
Nearest I can tell from all of them combined, you opened the hood. I can't find any procedures you've gone through to test parts, other than the obvious scanning for codes.
So please take more than 30 seconds to make a post, make a post, make a post, make a post and explain what you have done in detail so far.
Also, I find it coincidental that you didn't have problems until this Spectre intake was used. And no clue if you're still using it.
BTW, edit your thread and don't bypass the swear filter again. 1 and only warning I'm going to give.
121,000 members and still no sponsored racing.
iminhell is offline
Old 12-01-2012, 01:39 AM   #4
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,177, Level 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Level Up 14% Completed
Forum Activity 3%
FF Reputation: 4 matmatician Good Standing Member
How many miles on the 02 sensor? They do go bad, and that will give you a CEL in some cases. I had one until I replaced mine. Get one from Steve at Toulsey Ford, he'd good people.
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 12-01-2012, 02:17 AM   #5
Andrews-bad-SE
Fan#: 100389
I didn't bypass any filters, and I didn't swear. I don't even know how to do that. Calm down man. Also, I've made maybe 2 or 3 about this, and until the last one where someone told me about a trick to check for vaccuum leaks, nothing has come from it. I did search, before you start on that too.
I'm not using the Spectre thing anymore, I have an actual aluminium Factory Tuned CAI now.
Yeah, I opened the hood. I checked for vaccuum leaks. I put in a brand new sensor. I checked all my connections. I tried everything I could think of at the time. It's a code I've never dealt with before. Not everyone's a seasoned veteran dude. I have a $75 Mac Tools code reader, a craftsman toolbox, and a somewhat decent idea of what's going on. I'm not a Focus god like you and Tom. It's really annoying to see someone I have learned so many little things from go off on me like that. All I wanted was some advice.
Old 12-01-2012, 02:17 AM   #6
Andrews-bad-SE
Fan#: 100389
Possible causes:
ELECTRICAL
Damaged HO2S sensor
Damaged PCM
FUEL SYSTEM
INDUCTION SYSTEM
Air leaks after MAF
Vacuum leaks
PCV system
EGR SYSTEM:
Leaking gasket
Stuck EGR valve
BASE ENGINE
Oil overfill
Cam timing
This.... Thank you!!!
Old 12-01-2012, 02:19 AM   #7
Andrews-bad-SE
Fan#: 100389
I put in a new NTK p/n 22060, cleared the code, and it came up again.... The one that was in it was original, at 134,000mi.
Old 12-01-2012, 02:31 AM   #8
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,711, Level 94
Points: 23,711, Level: 94 Points: 23,711, Level: 94 Points: 23,711, Level: 94
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 14%
If I am not mistaken, NTK is not a recommend sensor for these... however I doubt that is the problem. 50% doubt anyway. bad new parts are of no surprise to me. verify that you have no exposed wires though.
I haven't posted in threads previous because it didn't make any sense. now that we have more information, I think you'll get some more help. Insulting other members won't get you far either though.
mikebontoft is online now
Old 12-01-2012, 02:38 AM   #9
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
NTK is the OEM manufacturer Mike, nothing wrong with using them. It's the Bosch O2's our cars don't like. I have a NTK and it's identical to the factory sensor.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 12-01-2012, 02:41 AM   #10
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 14%
really? well I'm glad you straightened that out then. I thought it was the other way around.
anyway OP... do you have multimeter?
