Thread sealer on brake lines? - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 11-30-2012, 07:57 PM   #1
FrozenNorthman
Fan#: 106844
What I Drive: 2001 White SE
FF Reputation: 1 FrozenNorthman Good Standing Member
Hey guys, this is my first time posting, this is quite the site you have here! I just replaced the brakes lines from the booster(is that right booster? not the master cylinder, but the secondary unit mounted on the drivers side, right near the firewall) to the calipers, including a new flex hose. when I pump the brakes, all I get is a gurgling sound, and fluid leaking from where the line meets the flex hose. my question is, should I be sealing this somehow, or will the fluid just eat the sealant? are there any other possible causes Ive overlooked?
FrozenNorthman is offline
Old 11-30-2012, 10:15 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
There is no place on a brake system where it is appropriate to use any kind of sealer.
I couldn't make sense of your post, but:
Brake boosters have no hydraulic lines, just a vacuum hose. The booster is mounted between the firewall and the master cylinder.
ABS units have hydraulic brake lines coming in/out of them.
elsolo is offline
Old 12-01-2012, 12:01 AM   #3
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
wait so did you replace the thing on top of the big black round thing or the plastic container right next to the fuse box?
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 12-01-2012, 07:18 AM   #4
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
FF Reputation: 21 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (14)
no sealant. either something isnt tightened all the way or its broken. Post up a pic, night be helpful.
I now drive a Japanese Ford.
macdiesel is online now
Old 12-01-2012, 01:36 PM   #5
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 64 sailor Excellent Standing Member
Major leakage when installing new brake lines is unfortunately all too common.
The seal comes from the metal of the brake line being "crushed" into the receptacle it attaches to, and it's critical that these pieces match & line up properly before final tightening.
The first common issue come from a mis-match of components. there are TWO types of flares for the end of the brake line in common use, and they do NOT interchange. The receptacle at the end of the flex line HAS to match the type of flare at the end of the steel line for it to seal.
If you look inside the union at the end of the flex line and see a "cone" shaped center, your steel line needs a recessed flare to match. If the flex union has a recessed center, your steel line needs a "ball" flare that protrudes to mate with it.
The second issue can come from trying to "force" the fittings together. When the steel line is bent to fit, it needs a straight end section that fits fully into the union B4 screwing in the compression nut. If this area is bent or angled into the fitting it can be pressed in off center by the nut and will NOT seat properly, leading to a leak that further tightening will not fix.
Making this situation even MORE fun, is the fact that sometimes a steel line will need different flares/nuts on each end to match the unions it attaches to. MOST generic steel lines have the same fittings on each end, so it's easy to end up with the wrong "match" at one of the ends if you don't know about this common pitfall.
Take another look, and see if one of these scenarios matches your problem.
luck!
sailor is online now
