2003 focus cranks...wont start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-30-2012, 08:45 AM   #1
tbjwool3
Fan#: 106797
What I Drive: 2003 ford focus zx5 blue
FF Reputation: 1 tbjwool3 Good Standing Member
Driving on t highwjat the car made a thunk sputter and a yellow cog light with ! Came on. Pulled off the highway and it stalled at a red light. Started back up ok and stalled again. It never started again. Some of the needle gauges cycle up and down after trying to start. The mechanic has checked timing...fuel pressure..compression...changed ignition selinoid. checking for blocked exhaust....he is baffled..and has checked many other sensors...won't start with starting fluid just backfires....like a timing issue....might it be the main computer and if so what is involved in changing it?
Thanks for your help or input
tbjwool3 is offline
Old 11-30-2012, 08:27 PM   #2
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
How did the mechanic check the timing. There are no timing marks. Have to go through a whole procedure to check timing.( Cam Bars and Such) Sounds like the timing belt jumped a few teeth. I would start by inspecting the belt all the way around for missing teeth.
iroc34 is offline
Old 11-30-2012, 08:34 PM   #3
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,026, Level 74
Points: 13,026, Level: 74 Points: 13,026, Level: 74 Points: 13,026, Level: 74
Level Up 44% Completed
Forum Activity 99%
And to add to this. How old & miles is on the belt & tensioner?
felixthecat is online now
Old 11-30-2012, 08:41 PM   #4
tbjwool3
Fan#: 106797
He did have to tear the engine apart to check timing...the belt was changed 10k ago. More history I have owned this car for 8 months. Has shimmy I can feel in steering wheel only on acceleration and has rough idle under load. I have changed ball joints bearings and tie rods...then had it aligned...motor mounts look good.
tbjwool3 is offline
Old 11-30-2012, 09:40 PM   #5
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,358, Level 20
Points: 1,358, Level: 20 Points: 1,358, Level: 20 Points: 1,358, Level: 20
Level Up 58% Completed
FF Reputation: 1 coldbear Good Standing Member
Did he check the crank sensor? I don't think it's a CPU.
coldbear is offline
