I think someone forgot to torque something - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-30-2012, 05:46 PM   #11
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,500, Level 21
Points: 1,500, Level: 21 Points: 1,500, Level: 21 Points: 1,500, Level: 21
Level Up 50% Completed
FF Reputation: 7 gondorian Good Standing Member
^This^
When you separate the ball joint it is pretty easy to get it some of the way in and think it is good to go. You have to be really sure it is all the way in before you tighten the bolt on the knuckle. You can't even judge very well by looking because the rubber boot on the ball joint covers up where it connects to the knuckle.
gondorian is offline
Old 11-30-2012, 06:07 PM   #12
mitchv
Fan#: 79720
What I Drive: 2003 blue zx3
FF Reputation: 4 mitchv Good Standing Member
little update. The place i got my car fixed is like a conglomerate of dealerships. like a bmw chrysler ford jeep thing combined and a dads friend works at the bmw part my car was originally fixed at the chrysler place and thats where it was towed too when this happened. My dads friend met with the head of the service dept at chrysler and he said that they didnt remove the ball joints, which is impossible to not do when you pull the engine and transmission out like they did. So my dads friend brought his mechanic over they talked about it with their mechanics and came to the conclusion it was their fault. So i got a phone call saying they will replace everything that needs to be replaced, fix the bent out front fender (ohh yea Ive got 1 "rolled" fender now). re align the car and if they have to replace my svt front shock
mitchv is offline
Old 11-30-2012, 06:14 PM   #13
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,762, Level 98
Points: 27,762, Level: 98 Points: 27,762, Level: 98 Points: 27,762, Level: 98
Level Up 42% Completed
Forum Activity 4%
That's great. Totally bad service manager though- apparently has no repair experience on FWD cars. I can't think of a single FWD that doesn't require the removal of axles to pull the engine.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-30-2012, 06:50 PM   #14
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,604, Level 53
Points: 6,604, Level: 53 Points: 6,604, Level: 53 Points: 6,604, Level: 53
Level Up 27% Completed
Forum Activity 48%
Activity: 48% Activity: 48% Activity: 48%
Buy-Sell-Trade Rating: (23)
That's great news Mitch!
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 11-30-2012, 08:31 PM   #15
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,795, Level 73
Points: 12,795, Level: 73 Points: 12,795, Level: 73 Points: 12,795, Level: 73
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 99%
Great you had some "pull" to get it settled without a major hassle!
Sounds like the initial response was an automatic "deny", that could have resulted in a long back & forth without your help from "cooler heads".
And yeah, if it's the right part & seated completely it CAN'T come out without the bolt coming out first. That's the "safety" in the design, even loose wouldn't let it pull out - the bolt has to be removed from the "groove" in the shaft B4 it can pull out....
Looking back to check your model year, there couldn't be a wrong joint either - since the '05 and up used a LARGER shaft for the joint, it wouldn't fit in your knuckle. If you had an '05 or newer, and an '04 or earlier ball joint was used it MIGHT give enough clearance to pull out if it was loose. Not your issue....
sailor is offline
Old 11-30-2012, 08:40 PM   #16
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,370, Level 100
Points: 138,370, Level: 100 Points: 138,370, Level: 100 Points: 138,370, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (11)
Those bolts are also one time use bolts though many have used them more than once. I replaced them on my SVT when I did my clutch cause I didn't want that to happen (was the 3rd or 4th time they were removed and were bent). Glad to hear they are fixing it and owning up to it. It's practically impossible to get the getrag out of the car with the front sub frame on it so they had to have removed it.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 11-30-2012, 09:55 PM   #17
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,358, Level 20
Points: 1,358, Level: 20 Points: 1,358, Level: 20 Points: 1,358, Level: 20
Level Up 58% Completed
FF Reputation: 1 coldbear Good Standing Member
Mitch I just had my lft. lwer ball joint disconnected. And the fellows are right. The "Clinch" bolt was distorted and bent. Took me three seconds to forget about reinstalling it. NAPA and many part stores can order them or FMC has a service bulletin out advising their line machanics to install new. It's a no brainer. Think about your families safety.
coldbear is offline
Old 12-03-2012, 01:00 AM   #18
mitchv
Fan#: 79720
Everytime I remove the ball joint, and I have a few times in the past, I always use a new bolt and torque it to spec. The bolts I use are completely black and thats what the car had on it before going into the shop. The bolt that was on the car when the ball joint fell out was grey So i know the shop did take the time to change the bolt they must of not had the ball joint in all the way
mitchv is offline
