Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 12-01-2012, 05:55 PM   #11
sailor
"Elder"
sailor's Avatar
Fan#: 57268
What I Drive: 2004 Pitch Black ZTS
FF Reputation: 48 sailor Great Standing Member
Okay, let's get back to "Lift Induced Oversteer" for a sec. here.
This is relatively minimized on a STOCK Focus because the emissions tuning does NOT allow for immediate engine braking when lifting (CAN be "tuned" to engine brake immediately, stock has a delay built in) There is still SOME of this effect just from the fronts NOT being "driven" anymore when you lift.
On a FWD car, when you "lift" it's like putting the front brakes on - nose dives, tail gets light, and it'll "step out" easier. If you are turning already, this will make the tail tend to drift more. (extreme case, if the tail is sliding already in the snow - it'll "snap oversteer" and you'll be tail first even if you steer into the slide. Been there, done that, when old RWD habits made me back off in a skid in my first FWD car)
Using this on purpose would involve steering into a turn, lifting a sec. to let the rear "rotate" a bit, then balancing the effect with throttle to continue the turn with the rear 'drifting" more than it otherwise would. This CAN result is a more "balanced" turn than FWD would otherwise allow.
The more extreme version (NOT "lift induced") is to "left foot brake" - keeping the throttle applied continuously while using the left foot to apply the brake. Engine power keeps the fronts "pulling" while the additional load on the rears from braking makes that end drift out more. It's kinda like a handbrake turn, but quite a bit more controlled.
Hope that helps keep the definitions straight, so we're talking about the same thing here.
Cheers!
sailor is offline
Old 12-01-2012, 06:17 PM   #12
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 34 felixthecat Great Standing Member
Very good exspanation Sailor.
Interduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
Old 12-04-2012, 08:34 AM   #13
bones33
Fan#: 105414
What I Drive: '05 Silver ST
FF Reputation: 1 bones33 Good Standing Member
Mr. Fordahl knows what he is doing. Smart guy, he is. I agree with getting some track time to get used to it at the limit in a safe environment.
Stock, cars are designed to understeer even while braking, you already know this. Sounds like your car is now nearly balanced and it just requires a different driving technique.
The turn described sounds like the one from the UW to 520 eastbound. A wet. tight, dropping, blind, decreasing radius right, often with stopped traffic somewhere not visible at the entrance. Yeah, that could be interesting entering hot and not knowing where (if) there is stopped traffic.
Please take care of yourself and others and attend an autocross school and get some track time. I didn't and destroyed 2 perfectly good vehicles, luckily nobody was hurt.
bones33 is offline
Old 12-04-2012, 08:50 AM   #14
mikebontoft
Gets more V8
mikebontoft's Avatar
Fan#: 58647
What I Drive: 1994 Toyota 4Runner
FF Reputation: 74 mikebontoft Excellent Standing Member
Ill have to come back and actually read but for the time being go watch season one or two of Initial D. someone explains all about fwd handling there XD
SR #127 | '02 Focus SE "Foci" (5.0 in progress) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-selling) | '94 Toyota 4Runner SR5 "Roach" (daily-stockish)
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
Originally Posted by GonOvr View Post
I had a spare tire go up in flames once, my truck was hit with an rpg though.
mikebontoft is offline
Old 12-05-2012, 01:06 AM   #15
Svizzara
Svizzara's Avatar
Fan#: 98554
What I Drive: '01 SPI Sedan
FF Reputation: 1 Svizzara Good Standing Member
This is quoted from my showroom thread. I thought it was fairly helpful:
Originally Posted by Malibooya View Post
Glad you want to learn! Here's why your friend crashed, aside from poor reflexes:
The Focus, unlike other economy cars of its day, has independent rear suspension. Most compacts (and even many mid-sizes) of the time used what's called a torsion beam design, which is pretty much what it sounds like. Basically a piece of steel connecting the two back wheels, so whatever one rear wheel does the other does.
Long story short, it usually means crap handling, and a lot of plowing even when lifting off (understeer). The Focus's rear suspension design allows it to give you what's known as "lift-off oversteer," which is another term that means exactly what it sounds like it does. Combine that with the Focus's short wheelbase, and you've got a lively little car even at base model trims (like your SPI).
So what probably happened: your friend was descending the hill, came in hot and lifted off while cornering and felt the rear go light. She panicked and slammed on the brakes, which caused the rear to come around even more. And BAM. There's your crash.
And this is what it led to, in my case. Stay safe out there
Svizzara is offline
Old 12-05-2012, 04:40 AM   #16
jinstall
Deutsche Arsche
jinstall's Avatar
Fan#: 9730
What I Drive: 01 ZX3RACECAR/04 ST170/13 FST2
FF Reputation: 4 jinstall Good Standing Member
Cheers!
Although this can be done at speed, it is not something you should try in the begining. You need to start out slow and then work your way up to higher speeds. Every driving school teaches this way.
2001 Focus ZX3 Race Car in Germany-Ours
2010 Renault Clio 1.2 16V in Germany-Hers
2004 SVTF EAP/ST170-Mine
2013 Focus ST2 TS NAV SUNROOF-Hers
jinstall is offline
Old 12-05-2012, 08:01 AM   #17
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
What I Drive: 2004 Red Focus SVT
FF Reputation: 1 TommyTooHi Good Standing Member
good words all, thanks.
It's actually the uphill decreasing radius on ramp from 108th (Kirkland/Bellevue) onto 405 North.
speaking of understeer, my old 1985 Subaru RX, the one-of-1500 grand dad of the WRX et al, on-demand dual-range '4WD' drove me NUTS in the slippy stuff. Plow..........
-T_T
Aw, heck - you mean what I know...
Mods: Caffeinated nut behind the steering wheel
TommyTooHi is offline
