Thermostat housing leak question, HELP - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-29-2012, 07:52 PM   #1
Mobsters1972
Fan#: 106806
What I Drive: 2002 silver svt
FF Reputation: 1 Mobsters1972 Good Standing Member
Hi, I am new here and I hope someone can help me. I had the thermostat leak in my 02 svt so I went and replaced it with new parts from Steve at Tousley ford. It fixed the leak against the block but it is now leaking at the temp sensor. I have had it out twice now and I cannot stop it from leaking. This new type sensor has a o-ring for sealing, it looks good to me but it is not doing its job in sealing. Has anyone else had this problem, if so how did you fit it.
I am afraid to tighten it to much in fear I might crack the housing, it There a torque spec for this sensor? I am using the good and tight method.
I called Steve at Tousley Ford and told him about my problem and he is sending me out a new seņor to try.
Ps: the last time I had it out I also put pipe thread sealant on the threads hoping it would help but still no luck.
Thank you for all your help.
Mobsters1972 is offline
Old 11-29-2012, 09:55 PM   #2
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,077, Level 27
Points: 2,077, Level: 27 Points: 2,077, Level: 27 Points: 2,077, Level: 27
Level Up 52% Completed
Forum Activity 6%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
I had the same problem, long story short I bought a pack of o-rings for the Contour sensor. I still have more spares than what I need, so if you need one let me know.
I tried pipe sealant, teflon tape, RTV and nothing worked but the o-ring.
Fox Hound: Liquid Stang - Sniper Focus - Decoy Escort (or was it a Tracer...)
Sniper Focus is offline
Old 11-29-2012, 10:15 PM   #3
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
Buy-Sell-Trade Rating: (4)
Is the the sensor ontop of the housing, or the plug on the underside?
if you bought it from steve, did he not recommend the contour t-stat housing?
BigRed03 is offline
Old 11-30-2012, 04:52 AM   #4
Mobsters1972
Fan#: 106806
Temp sensor leak
Yes it is the new contour style housing from Steve.
Old 11-30-2012, 04:53 AM   #5
Mobsters1972
Fan#: 106806
Sniper focus, do u know what size o
-ring it is?
Old 11-30-2012, 02:58 PM   #6
Sniper Focus
Fan#: 84221
Forum Activity 6%
-ring it is?
110 Viton o-ring, I had to get a pack of 25, but it was cheaper than a new sensor.
Old 12-10-2012, 09:59 PM   #7
SWEGER
SWEGER's Avatar
Fan#: 88926
What I Drive: 2003 Infra-Red ZX5 SVT
FF Reputation: 1 SWEGER Good Standing Member
My leak is back...really tempted to buy the upgraded housing but do not like the idea of spending $100+ to fix this. How long have yours been holding? What durometer are the ones you ordered?
Size 110 is 3/8" ID, 9/16" OD, and 3/32" thickness right?
2003 Infra-Red ZX5 SVT - Cheap Spectre intake (don't judge, was on there when I got it), Hawk HPS pads front/rear, Russell SS lines, Goodyear Eagle GT 215/45/17
"If guns cause violence, then all of mine are defective" - Ted Nugent
SWEGER is offline
Old 12-10-2012, 10:19 PM   #8
Sniper Focus
Fan#: 84221
Forum Activity 6%
The 110 is for the Contour ECT sensor only, stock uses a 2xx size. I didn't bother with the stock housing because the head side o-ring channel on the housing failed, which is common.
Old 12-10-2012, 10:40 PM   #9
SWEGER
SWEGER's Avatar
Fan#: 88926
Gotcha thanks man...ill probably just end up getting the contour housing. Seems to be the best fix
SWEGER is offline
Old 12-11-2012, 08:00 PM   #10
..:: sleestak ::..
on thin air
..:: sleestak ::..'s Avatar
Fan#: 22528
What I Drive: 04 Forester XTi
Points 14,599, Level 78
Points: 14,599, Level: 78 Points: 14,599, Level: 78 Points: 14,599, Level: 78
Level Up 38% Completed
FF Reputation: 80 ..:: sleestak ::.. Excellent Standing Member
Buy-Sell-Trade Rating: (15)
spend the money for the metal housing and be done with it.
fyi - a common cause of cracked housings is a leaky/seeping valve cover gasket. The oil gets hot and goes down the side of the engine, between the housing and motor. The o-ring swells and cracks the housing.
..:: sleestak ::..
"Our mother of blessed accelleration, dont fail us now!" -- Elwood Blues
..:: sleestak ::.. is offline
