2008-2011 Projector Retrofit Guide: Morimoto Mini H1 - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-16-2013, 03:19 PM   #51
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
Originally Posted by DarderSauce View Post
So I just realized I bought the DS2's instead of H1's. The only difference I can see between the two is Projectors, Ballasts, and bulbs.
H1
Projectors:
Morimoto Mini H1 6.0 Bi-xenon
Ballasts:
Morimoto 3Five
Bulbs:
Morimoto 3Five H1
DS2
Projectors:
Morimoto Mini D2S 2.0 Bi-xenon
Ballasts:
Morimoto 3Five/5Five
Bulbs:
Morimoto D2S
Can anyone tell me what the difference is specifically or are the DS2's just a step above the H1's?
Also wondering if the DS2's have the same problem with the solenoid sticking on the high beam setting?
H1 is better than the D2s.
Both use the same projectors, just different bulbs.
D2s allows you to use OEM ballasts and stuff though
A7xschecter6661 is offline
Old 04-16-2013, 04:19 PM   #52
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
do the DS2 projectors have the same issue as the H1's regarding the high beam solenoid sticking?
If you can't wear it out, burn it off
DarderSauce is offline
Old 04-16-2013, 10:57 PM   #53
A7xschecter6661
Fan#: 98263
Yes it's the same projector just a different bulb. So the same solenoid is there.
I recommend doing the pre install suggestions and also modding the lens for some color like mine!
Old 04-17-2013, 08:31 AM   #54
DarderSauce
Fan#: 95564
So, lets say I've got an acquaintance that could get my solenoids coated in teflon, that would be just as good (if not better) than using the high temp lube right?
Also I plan on modding the lense (assuming you mean washer trick) to get the bluish/purple cutoff you've got. I am also going to paint the cutoff shield to get the "Blue Eyes" effect.
Old 04-17-2013, 01:05 PM   #55
A7xschecter6661
Fan#: 98263
Teflon should work. As long as you sand it down (not too much! I used like 2000 grit sandpaper, put the solenoid plunger in a drill and spun it against the paper).
No sticking issues since i did my second set
Old 04-26-2013, 09:02 AM   #56
DarderSauce
Fan#: 95564
Untitled by DarderSauce, on Flickr
With Camera Flash
Old 04-26-2013, 10:33 AM   #57
A7xschecter6661
Fan#: 98263
Looking good! Got your Butyl ready?
Are they aimed and ready for the lens? Did you sand down the plungers and put some washers in to give it a blue cutoff?
Old 04-26-2013, 10:56 AM   #58
DarderSauce
Fan#: 95564
Butyl: Ready
Aimed: Not yet, heading home to aim them on a long stretch of flat ground
Plungers: Sanded and sprayed with lube (they were too small for teflon coating). Couldn't find graphite Jig-A-Loo anywhere so I used liquid wrench to lube it up.
Washers: Yup, put 3 on the bottom like you did.
Excited to see what kind of output I get with these.
Old 04-27-2013, 09:26 AM   #59
A7xschecter6661
Fan#: 98263
Originally Posted by dardersauce View Post
butyl: Ready
aimed: Not yet, heading home to aim them on a long stretch of flat ground
plungers: Sanded and sprayed with lube (they were too small for teflon coating). Couldn't find graphite jig-a-loo anywhere so i used liquid wrench to lube it up.
Excited to see what kind of output i get with these.
awesome! More pics!!!!
Old 04-29-2013, 12:25 PM   #60
DarderSauce
Fan#: 95564
Hit a snag, the harness I hooked up doesn't have power to the projector plug-ins. The harness puts power to the fuse but after that, nothing. I don't think I hooked it up wrong (kinda hard) if the fuse (not burnt out) is getting power and the projector plugs aren't. We'll see what TRS says.
Is this what your harness looKS like?
Morimoto_HD_Low_Beam_Harness-1 by DarderSauce, on Flickr
A7xschecter6661: What did you do with the factory bulb plugins that don't get used with the new harness?
