Eibach pro kit Dead coil cutting on ST 170 (SVTY - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-28-2012, 05:23 PM   #1
cossieboy
cossieboy's Avatar
Fan#: 89896
What I Drive: 2004 ,moonlight silver ,st 170
Points 1,880, Level 25
Points: 1,880, Level: 25 Points: 1,880, Level: 25 Points: 1,880, Level: 25
Level Up 80% Completed
FF Reputation: 1 cossieboy Good Standing Member
Hi guys , i have ano Eibach pro kit 20 25mm drop on my focus st 170 , the front is perfect , the rear is still 4x4 status , i have removed the rubber insulators where the spring sits on but still not happy , whats your views on cutting dead coils with regards to ride quality , handling , tyre wear etc , ps. The front has half a finger space between the tyre and the fender and the rear has 2 and a half finger space , i jus wanna get the back closer to the front height , if you agree on cutting dead coils ,will cutting of one coil be sufficient .Many thanks
Lifes too short to wait for the v - tec to kick in . Live it in an st
Killerwats is how fast you hit the wall
Torque is how far you draggggggggg the wall
Speed dosent kill its the sudden stop that does
cossieboy is offline
Old 11-28-2012, 06:10 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
A dead coil is just that....dead. It does nothing from a spring oscillation point of view. It only impacts ride height by the diameter of the wire used. So if the dead coil is 1/2 in diameter (as an example) cutting a full coil will reduce height by that amount. Using this example, to reduce height 1.5 inches you'd have to cut 3 full dead coils. I don't know if you have that many dead coils, but it's something to keep in mind. The dead coils can also play an important roll of keeping the spring seated especially under rebound conditions (most dead coils are only dead under load, when free (aka free length) there's usually some space between each coil). People have cut springs and literally seen them fall out when the suspension becomes unloaded (e.g. going over a hill) due to a lack of adequate length to hold them in.
Geezer is offline
Old 11-28-2012, 08:16 PM   #3
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 99%
Grab your stock coils & cut 1.5 coils off & then install them. I had the frpp's K/W springs & the rear sat up higher, so I cut 1.5 coils out of the oems & that fixed the height issue.
felixthecat is offline
Old 11-29-2012, 01:09 AM   #4
cossieboy
cossieboy's Avatar
Fan#: 89896
Bump . Guys how about a little help here?
Old 11-29-2012, 08:16 AM   #5
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
Did you not read what Greezer & I replied in your thread?^^^
Old 11-29-2012, 12:01 PM   #6
Geezer
Fan#: 1427
What more are you looking for? There is no definitive yes or no answer to your question. There are tradeoffs and impacts that must be considered. If you truly want to do this correctly you should get a set of fully adjustable coilover springs and shocks. They allow for "fine" tuning without the fear of springs clanking around in their seats and mounts.
Geezer is offline
Old 11-29-2012, 03:45 PM   #7
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,551, Level 48
Points: 5,551, Level: 48 Points: 5,551, Level: 48 Points: 5,551, Level: 48
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 8%
FF Reputation: 35 thenorm Great Standing Member
along these lines. are you using lowering shocks, or oem. OEM shocks are too long, will droop too much, and you spring may fall out. many aftermarket shocks matched to lowering springs are them selves shorter.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 11-29-2012, 03:59 PM   #8
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
Very good point. ^^^^^^^^^^ Thats why its best to go w/ matched dampers w/ lowering springs.
Old 11-29-2012, 10:46 PM   #9
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
Points 6,733, Level 53
Points: 6,733, Level: 53 Points: 6,733, Level: 53 Points: 6,733, Level: 53
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 4 ChrisRobin Good Standing Member
I say try with a dead coil or two and see how it sits. Trial and error
Originally Posted by WRCwannabe View Post
...and then slap a supercharger on it and rape their tits off.
ChrisRobin is offline
Old 11-30-2012, 04:38 AM   #10
cossieboy
cossieboy's Avatar
Fan#: 89896
Thanks guys
