koke's turbo kit build - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-19-2012, 12:32 AM   #81
Black00ZX3
Fan#: 104714
What I Drive: '12 Silver Focus
Points 1,902, Level 26
Points: 1,902, Level: 26 Points: 1,902, Level: 26 Points: 1,902, Level: 26
Level Up 2% Completed
FF Reputation: 3 Black00ZX3 Good Standing Member
If you suspect your head gasket is bad the easiest way to tell is to pull the plugs out and check for oil.
Black00ZX3 is offline
Old 12-19-2012, 12:43 AM   #82
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Ok thanks I check that out tomorrow
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 12-19-2012, 07:08 AM   #83
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
normally yes and when your headgasket blows you have terrible compression
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 12-19-2012, 07:11 AM   #84
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
I'm confused...how bad did your car overheat on the dyno? Did they keep doing WOT runs back to back or turn the fans off? Has your car overheated before to make you change the thermostat? What makes you think the head gasket is bad?
When I took my car to McNews: First Ray did some easy pulls through the RPM band to check the base tune (which was pretty good). Then made some tweaks, loaded new tune (that took 5-10 mins with the XCAL2). Then 1 WOT run. Made some tweaks then loaded new tune (another 5-10 mins to load). Then 1 WOT run. Made some final tweaks and loaded the final tune (another 5-10 mins to load). Then the final dyno pull for numbers. Basically there was always cool down periods between runs while Ray tweaked the tune and then loaded it. Granted loading a tune with the XCAL3 is quicker but there is still cool down time.
What da heck was being done on your dyno runs? The Duratec cooling system is very efficient I never once had any issues with overheating even at ambient temps close to 100* F and sitting in traffic.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 12-19-2012, 09:30 AM   #85
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,090, Level 55
Points: 7,090, Level: 55 Points: 7,090, Level: 55 Points: 7,090, Level: 55
Level Up 70% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
^yeah Griz, I'm curious also. I'm wondering if the car had a cooling system issue prior to the dyno runs.
As far as the head gasket you could do a compression test.
The Focus is a different beast when it comes to tuning. You may want to consider going to a tuner with experience in tuning the Focus.
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 12-19-2012, 11:48 AM   #86
koke'sfocus
Fan#: 69779
This is the thing my car has never over heated or it over heated in the dyno the problem was he was doing some adjustments in the base tune doing some crusing pulls and the temp went to almost 220* he said that wasn't normal that the temp should be arround 190 that maybe was wrong with my car probably te head gasket, and one of the problems I notice is that my heater didn't blow the air that hot and now that I change the thermostat obviously the problem went away I never hange the antifreeze before so I surely think that was the problem and about if he has ever tune focuses he has he tuned focussport423
team duratec #94
D23 crew #9.
Old 12-19-2012, 01:08 PM   #87
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
If the thermostat fixed the problem and the compression test checks out I'd say your good to go!
1988 F150 Custom
D23 Crew: #07
Old 12-19-2012, 02:54 PM   #88
koke'sfocus
Fan#: 69779
Well I just finish the block leak test and the liquid didn't change is color so I schedule a tuning sesion for tomorrow morning I let everyone know how it went :)
team duratec #94
D23 crew #9.
Old 12-20-2012, 06:30 PM   #89
mikealicious
'Merica
mikealicious's Avatar
Fan#: 47077
What I Drive: 2002 Black SVT (gone), 2012 SEL
Points 8,576, Level 62
Points: 8,576, Level: 62 Points: 8,576, Level: 62 Points: 8,576, Level: 62
Level Up 43% Completed
FF Reputation: 8 mikealicious Good Standing Member
so how'd it go?
Visit here to see fast cars and races. ---> YouTube: mikealicious2k5
mikealicious is offline
Old 12-20-2012, 09:29 PM   #90
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
Yea so what's new
FF MODERATOR
RIFF CREW
