koke's turbo kit build - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-07-2014, 03:28 PM   #151
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Its a huge turbo lol
Originally Posted by ZXthrizzle05 View Post
How is the boost that low and number that high? I'd be lucky to get 250 on 12
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 02-08-2014, 06:00 PM   #152
jinstall
Deutsche Arsche
jinstall's Avatar
Fan#: 9730
What I Drive: 01 ZX3RACECAR/04 ST170/13 FST2
Points 2,807, Level 32
Points: 2,807, Level: 32 Points: 2,807, Level: 32 Points: 2,807, Level: 32
Level Up 38% Completed
Forum Activity 11%
FF Reputation: 4 jinstall Good Standing Member
Yea, you have to wait another week. Too much sand on the track. Wind was gett bad around noon friday.
2001 Focus ZX3 Race Car in Germany-Ours SHIPPING
2010 Renault Clio 1.2 16V in Germany-Hers FOR SALE
2004 SVTF EAP/ST170-Mine
2013 Focus ST2 TS NAV SUNROOF-Hers
jinstall is offline
Old 02-08-2014, 08:02 PM   #153
koke'sfocus
Fan#: 69779
Yeah I know man that sucks but its ok lol cant wait to see my new time in the 1/4 :D but maybe ill go tomorrow to run the car in juarez there is an event there
team duratec #94
D23 crew #9.
Old 02-08-2014, 08:19 PM   #154
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
I hada 5857 precision that would reach max at 4100 rpm, I like my gt2871r much more
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 02-08-2014, 08:50 PM   #155
Hughesy27
Hughesy27's Avatar
Fan#: 84331
What I Drive: 2010 blue se
Points 1,777, Level 24
Points: 1,777, Level: 24 Points: 1,777, Level: 24 Points: 1,777, Level: 24
Level Up 77% Completed
Forum Activity 6%
FF Reputation: 1 Hughesy27 Good Standing Member
What size housing do you have on there? They make aftermarket ones for external wastegate and pretty cheap too. Comes with a vband flange. The smaller housing is still pretty big but should help with spool.
Hughesy27 is offline
Old 02-09-2014, 02:20 PM   #156
koke'sfocus
Fan#: 69779
I have the 7 blade hx35 and I saw a 12cm exhaust housing but I read that housing is the one that come with the 7 blade but I don't really know for sure
team duratec #94
D23 crew #9.
Old 02-09-2014, 03:19 PM   #157
Hughesy27
Hughesy27's Avatar
Fan#: 84331
Forum Activity 6%
Not sure if the 12cm would end up choking you in higher boost. Most of the ones I saw come stock with 18cm. The housings I saw were 16cm. I'll do some more research and check out the flow capabilities for both.
Old 02-09-2014, 06:11 PM   #158
koke'sfocus
Fan#: 69779
Look for info on the dsm forums I I read that the 12cm is for better spooling times and depends in the turbo manifold so It can be restrictive or not
team duratec #94
D23 crew #9.
Old 02-09-2014, 06:15 PM   #159
koke'sfocus
Fan#: 69779
The 7blade hx35 has a 54mm compressor inducer. This is found on the 1999-2002 cummins manual pickups. The compressor flows 60lb/min according to the compressor map and logged results from a member here. The bolton BEP housing with the hx35 turbine wheel do not SEEM to have enough flow to really reach the potential of 60lb/min. But many have logged over 50lb/min so far and seen 500whp. The stock hx35 12cm^2 twinscroll turbine housing is a t3 flange housing. This mated to a NON-divided runner manifold has produced a 132mph trap speed with a full weight 1g AWD. This is about 600whp. So the flow is there with the stock housing if you use a non-divided manifold. The spool speed of the 7blade hx35 is similar to the 8blade hx35 with 20+ psi by 3500rpms in the bolton housing and by 4000rpms with the stock housing with a non-divided manifold.
team duratec #94
D23 crew #9.
Old 02-09-2014, 06:24 PM   #160
Hughesy27
Hughesy27's Avatar
Fan#: 84331
Forum Activity 6%
That's the same one I was reading. I thought the stock housing was bigger than that. So are you running the 12? I keep seeing the 18 every where but could be wrong. If I get it I plan on swapping the housing out anyway. I'm torn on which turbo to get. I'd like to see how it does on the fs t3 manifold I got.
