Where to Get Rear Lower Control Arm Bolts - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-28-2012, 12:30 PM   #1
FlashJT
Fan#: 106751
What I Drive: 2005 Ford Focus Wagon, Silver
FF Reputation: 1 FlashJT Good Standing Member
I've been looking around the forums all morning, and I've come to the conclusion that I'm going to need to cut off the control arm bolts and replace the control arms. I can find the control arms pretty easily (seems RockAuto is the place to get them cheapest) , but where do I get the bolts at? Do those have to be sourced directly from ford? Or can they be obtained online somewhere? Seems that every thread that talks about replacing the control arms doesn't mention where the new bolts are obtained.
I'll be working on a 2005 Wagon if it makes any difference.
FlashJT is offline
Old 11-28-2012, 01:07 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
I wouldn't see why bolts from a hardware store
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 11-28-2012, 01:12 PM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Take what's left of the bolt to you're auto parts store (I've had good luck at NAPA and independents for things like nuts and bolts). The head of the bolt usually has the strength/grade markings on it so try to salvage that. There's not special about them. They just need to be the correct length, grade, and diameter. Your friendly hardware store can probably set you up as well.
Geezer is offline
Old 11-28-2012, 01:14 PM   #4
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
Points 15,532, Level 80
Points: 15,532, Level: 80 Points: 15,532, Level: 80 Points: 15,532, Level: 80
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 2%
FF Reputation: 20 xxMichaelAnthony Great Standing Member
Just my personal preference but Id get them at Ford.
http://effyeahfordcars.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 11-29-2012, 11:56 PM   #5
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
I had the same problem finding rear suspension parts a few months ago, so I did the job and then recorded my purchases in this thread:
http://www.focusfanatics.com/forum/showthread.php?t=297299
scroll down to post #10
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 11-30-2012, 10:24 AM   #6
FlashJT
Fan#: 106751
Thanks for the reply my_beautious_ZX3. Based on the part numbers listed in your post, I was able to google and find a few other posts about these nuts/bolts. One of them listed them as:
6S4Z-5K751-AA (CAM)
W500746-S439 (BOLT)
6S4Z-5K978-AA (BOLT)
W703016-S306 (NUT)
It looks like W500746-S439 is the bolt I need for the tire side of the LCA.
It also looks like 6S4Z-5K798-AA is the bolt for the other end of the LCA that attaches near the middle of the car.
Where is the CAM bolt at? Does that need to be replaced along with the other two LCA bolts?
Only one nut was listed....W703016-S306....is that nut the same for ALL of these bolts?
I don't want to go to a hardware store and get the nuts/bolts. I don't trust myself to get the right grade/hardness/etc. I also don't like paying more for hardware than I have to, but the safety of my wife/kids (primary users of the focus) is more important than saving a few bucks.
If I can find the part numbers for all of the nuts/bolts I need to replace the rear LCAs, I can just order them offline somewhere. I just need to make sure I have all of the right part numbers for everything I'll need. Can anyone verify the above list is what I will need?
FlashJT is offline
Old 11-30-2012, 11:59 AM   #7
my_beautious_ZX3
Fan#: 32386
I can't comment on that because I just used generic hardened hardware from the hardware store for the tire side.
correct, but your part # has a typo
like I said in my post, 6S4Z-5K978-AA = cam bolt. "Cam" refers to the eccentric that is integrated into the bolt; think "cam shaft". Someone just posted a sweet pic of one: http://www.focusfanatics.com/forum/showthread.php?t=303384
I don't know, a Ford dealer could answer that.
in my experience, only a dealer stocks this kind of hardware. Alot of folks on this forum have found that Tousley Ford has slightly lower prices than your local dealer.
Each LCA has one toe adjuster in the center of the car, which is composed of three parts - the cam bolt (cam integrated into a bolt), a loose cam that slides on the opposite side of the cam bolt, and a nut to keep it all together. The only thing that appears to be missing from your list is one loose cam for each LCA; $12/ea at Ford unless you reuse your old ones.
Old 12-01-2012, 10:33 AM   #8
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,500, Level 21
Points: 1,500, Level: 21 Points: 1,500, Level: 21 Points: 1,500, Level: 21
Level Up 50% Completed
FF Reputation: 7 gondorian Good Standing Member
I would just reuse the old cam. Even if you have to cut off the old bolt the cam should still be good.
gondorian is offline
Old 12-01-2012, 10:43 AM   #9
euro-bred
euro-bred's Avatar
Fan#: 30047
What I Drive: 04 2.3 zx3
Points 1,736, Level 24
Points: 1,736, Level: 24 Points: 1,736, Level: 24 Points: 1,736, Level: 24
Level Up 36% Completed
FF Reputation: 10 euro-bred Great Standing Member
Buy-Sell-Trade Rating: (4)
or you could pm me, for that i collect these bolts for such occasions to help out fellow fanatics in times of need!
euro-bred is offline
Old 12-02-2012, 10:35 AM   #10
gopromiller
Fan#: 106819
What I Drive: 2005 red zx3
FF Reputation: 1 gopromiller Good Standing Member
yeah,me too.I would just reuse the old cam. Even if you have to cut off the old bolt the cam should still be good.
gopromiller is offline
