Ford Focus shaking up and down at speeds 30km/h-50km/h (I'm canadian lol) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-28-2012, 11:12 AM   #1
gello88
gello88's Avatar
Fan#: 102250
What I Drive: 2000 Black ZX3
FF Reputation: 1 gello88 Good Standing Member
Right so I just got my brakes done and all is well now in that regard. At the same time, I installed my winter steel rims and tyres. Driving down the highway I noticed that when I was at speeds 30-50km/h (rush hour) on the relatively smooth tarmac of the highway, I felt the car shake up and down. Not too violent but enough for me to notice. Then when I speed up to highway speeds it dies down but that maybe because I'm going much faster that the frequency of the vibration is too fast it's not noticeable anymore. I'm bringing it back in to the shop tomorrow to get it checked out but just out of curiosity what could cause this?
I personally am pointing at the new steel rims that I just installed but any other opinion? Everything is torqued to specification by the way
gello88 is offline
Old 11-28-2012, 11:16 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,890, Level 59
Points: 7,890, Level: 59 Points: 7,890, Level: 59 Points: 7,890, Level: 59
Level Up 70% Completed
Forum Activity 30%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Were the steel wheels/tires balanced before they were installed? That's one that will cause different vibrations at different speeds and is easy/cheap to fix but if they were balanced already, you can cross that off the list.
rambleon84 is online now
Old 11-28-2012, 11:30 AM   #3
gello88
gello88's Avatar
Fan#: 102250
I'm actually not sure if they were :( but it didn't happen with my alloy wheels that were on before I put on the steel rims
gello88 is offline
Old 11-28-2012, 12:03 PM   #4
gello88
gello88's Avatar
Fan#: 102250
Just an addition, the steel wheels that I bought was not specifically designed for the car. Instead it was the typical steel wheel that had the right lug pattern. I read somewhere before that the alloys are pretty thick where it mounts to the hub, my steels are well, just that, bare steel. Could it be that I may need wheel spacers to have the right offset?
gello88 is offline
Old 11-28-2012, 03:45 PM   #5
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,617, Level 48
Points: 5,617, Level: 48 Points: 5,617, Level: 48 Points: 5,617, Level: 48
Level Up 34% Completed
Forum Activity 4%
FF Reputation: 36 thenorm Great Standing Member
offset shouldnt matter.
the wheels are tight against the hub? and the lugnuts arent bottomed out? (open or closed lugs?)
I'm betting on wheel balance.
yo can easily check the out lip of your wheels, there should be a crimp on weight on each wheel.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 11-28-2012, 08:54 PM   #6
gello88
gello88's Avatar
Fan#: 102250
The lugnuts are open (thats when the lugnuts are open on both ends right?) The wheels are tight against the hub, I tightened the lugnuts to spec (95 lbs. ft.).
The steel wheels that I'm using are aftermarket but I told the store that it's for my Ford Focus and they gave me the wheels. They lugnut holes fit perfectly on the hub. Not sure if the wheels are hub-centric though. How do you even know if it's "hub-centric" ?
I also did notice that one of the steel wheels do not have any wheel weights. The other three steel wheels have wheel weights.
gello88 is offline
Old 11-29-2012, 08:55 PM   #7
gello88
gello88's Avatar
Fan#: 102250
So I just went and got the car checked out at a local tire shop. They said the rear links were loose and the wheels were not perfectly balanced. So they sorted that out, tightened the links and balanced the wheels. They said it was good. When I drove it today, I definitely felt an improvement but I still feel a slight vibration. What could be wrong now? I'm gonna go back and get it checked out again...
gello88 is offline
Old 11-30-2012, 04:08 PM   #8
gello88
gello88's Avatar
Fan#: 102250
So just sort of a final update. I went back to the tire shop (really nice people) and they showed me that one of the wheels are off center as in one of the lug nut holes is damaged and hence even if it is torqued properly, the wheel will not sit centered since it is not hub centric. So with all that, we decided to just switch back to my OEM alloys and mount the winters there. Problem is now solved.
So for me in the future, I will just buy OEM alloy wheels that are hub centric so this sort of stuff doesn't happen. My steelies are just sitting there now. I'm just probably gonna sell it to the junk yard or something.
gello88 is offline
